Question about Canon S 750 InkJet Printer
Failure to print in Black ink
Printer makes action and noise as if printing but nothing comes out. Also under properties i have to lower the black and increase the other colours. I have put in a new cartridge and cleaned it but nothing seems to work.
  • 1 more comment
  • A Taylor Apr 09, 2008
    Printing in black only shows only partial letters
    When I print using my Canon S750 I get only partial characters. Many attempt at deep cleaning and alignment have not resolved this issue
  • dh5786 Jul 06, 2008
    Same problem - Canon S750 printer doesn't print black ink.
    There are no instructions anywhere to clean the waste ink system(?) pads(?).
    I tried cleaning cycle, deep cleaning cycle, soaking print head in water until cleean, doesn't help.
  • 59 Answers
I see this alot in epsons. What is happening is probably this:
The carriage that you put your cartridges in is called a printhead.
connected to the printhead is a long tube for pumping wasted ink down to a waste pad that soaks up the ink. Over time the ink builds and clogs the hose, which backs up and clogs the print head. It is usually more common to happen at the install of a fresh cartridge and it does that first charge. To make a long story short, unless you can hot chemicals to run through it, it is dying.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I know I am not low on ink (black) but I can't print anything in gray scale-comes out cyan. Changed black ink to a brand-new tank and still nothing. Took out CMY tank and still nothing. Worked the...
When you go to print, next to the printer selected hit "Properties". This may vary for various printers but under my Color options there is an option to print in grayscale. Look for this option and select it. Also, under print in grayscale it has an option to print in black ink only. Look for these options under your printer's settings.
Jun 04, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I just bought a new printer today its a lenmark Z2300m Color Printer i only have color ink for it do i need black ink for it because everytime i try to print it comes out greenish
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print.
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black text Printing using Photo Black
You should be able to set the cartridge it uses when you print, as something like 'Print only black'. Fish around in the printer window when it comes up when it comes up. You may also be able to set this as a default in 'Properties' from the 'Printers' option in Windows, but then it will always try to do this, of course, which you may not want.
Jun 26, 2009 | Canon MP610 Photo All-In-One Printer
Epson styus cx5000
Go into Printers, Properties, Printing Preferences, then Black Ink Only. If you make that the default, it will automatically print black ink with you click on the printer in the toolbar. If you want to print one document in color, click on File, Print, Properties, and set it for color for that one job only. The default of Black Ink should stay the same.
Aug 28, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Greyscale Printing
Jul 26, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Printing Problems
In Windows 98/ME/2000:
1. Go to START, SETTINGS, PRINTERS.
2. RIGHT CLICK on your Epson printer name; left click on PROPERTIES.(PRINTING PREFERENCES in Windows 2000).
3. Go to the MAIN tab.
4. Place a check beside BLACK INK ONLY.
5. Click APPLY then OK.
In Windows XP:
1. Go to START, CONTROL PANEL, PRINTERS AND OTHER HARDWARE or PRINTERS AND FAXES. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear).
2. RIGHT CLICK on your Epson printer name; left click PRINTING PREFERENCES.
3. On the MAIN tab.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
Dec 28, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Canon S 750 InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
