Question about HP PSC 1610v All-in-One Printer
1610v keeps saying it is out of paper....it is not.
Prints 15 pages then says out of paper. lot of paper left
Depending on the poundage of the paper the paper can acutally stick to one another. Simply fan the paper out by running your finger across the edge that will be loading into the printer (sort of like you are looking at a flip book) and then load the paper in. This puts air between and "unsticks" the pages, this a lot of times fixes this problem.
Feb 28, 2011 | HP PSC 1610v All-in-One Printer
The paper keeps on jamming now and/or coming out the back end of printer. I'm using the correct HP paper? What can I do?
Remove the back cover from back of printer. (by holding notch and pressing to the right side then pulling)
The part removed is responsible for directing paper to the top. Clean rollers by as applying a lighly damped lint free cloth and check if every roller is turning by finger.
Now, put back the cover by inserting the right side first and push.
Good luck
Nov 29, 2010 | HP PSC 1610v All-in-One Printer
Printer saying paper jam no jam and paper keeps stopping and light comes on.
Paper jams are detected by little wires connected to switches. Sometimes when you clear a jam a wire will get bent or twisted so it closes the switch it is connected to. Check all wires to make sure they are straight and free to move...
Sep 22, 2010 | HP PSC 1610v All-in-One Printer
Printer keeps saying it is out of paper...when there is plenty in the carriage...??
A COMMON HP PROBLEM. TRY TO UNINSTAL THE SOFTWARE. REBOOT COMPUTER AND REINSTALL SOFTWARE. GO TO HP AND TRY TO UPDATE THE DRIVERS, ALSO GO TO MICROSOFT UPDATE TO SEE IF EVERYTHING IS CURRENT. SEE IF U ARE USING THE LATEST .NET SYSTEM ON YOUR COMPUTER. IN THE ADD/REMOVE PROGRAMS U WILL FIND A LIST OF ALL THE CURRENT PROGRAMS ON UR SYSTEM.
Jan 09, 2010 | HP PSC 1610v All-in-One Printer
When i start my printer it has an error sign
I think this is a paper size error code. Im not sure how to overcome it. Try reinstalling the driver and/or see if HP has a updated driver for your 1610v
thanks for your question
Jan 04, 2010 | HP PSC 1610v All-in-One Printer
My Hp Psc 1610v All-in-One eats my vellum paper
The paper is too thick and you can't use it on this copier.
Nov 12, 2008 | HP PSC 1610v All-in-One Printer
WON'T TAKE PAPER; SAYS OUT OF PAPER,
I had that problem and I feathered my paper in a "stairstep" instead of putting the paper in all flush and it solved my problem. I can print continuously without getting the "out of paper" error message now.
Sep 28, 2008 | HP PSC 1610v All-in-One Printer
Cannot run printer...stuck on Initializing
hi,
please go through the following link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01330821&cc=us&lc=en&dlc=en&product=390328
thanks and regards
agnel
Jul 15, 2008 | HP PSC 1610v All-in-One Printer
Problem with ink cartridge
There is something broke with the piece that keeps it in place. You need to take it out and look real close to how it works. Look at how the color works and compare the two.
Sep 23, 2006 | HP PSC 1610v All-in-One Printer
HP PSC 1610v All-in-One Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
