Question about Hunter 28096 Westminster 52" Ceiling Fan with Light
Light fixtures goes off/on intermit while in the ON position. Fan works fine. When it goes OFF, it can't be turned ON.
  • 95 Answers
Es screw lamps req tghtening to make better contact in lamp housing
Posted on Nov 18, 2009
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
Magic fan
u need to show a good technision of electronic
Jul 19, 2008 | Hunter 21617 Palermo Brushed Nickel...
Why don't the lights turn on?
Could be a defective light switch
Jul 26, 2015 | Dryers
How can I turn off the lights on a ceiling fan?
Try to find the breaker that controls power going to that fan/light, turn the breaker off, wait 5-10 minutes, then return breaker to the on position, doing so 'may' be able to reset the control board inside the fan itself. If this has no success, the lighting control board is malfunctioning, if still under warranty, you have options outside of replacing the complete fixture.
Aug 17, 2014 | Dryers
CEILING FAN WORKS,BUT REMOTE ONLY WORKS THE FAN SECTION, WILL NOT DIM LIGHTS NOR TURN OFF LIGHTS ONLY SO WE CAN USE FAN ONLY. WHAT DO WE HAVE TO DO?
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Wired up this fan - blue and black together to the black wire, white to the white and green to the ground. The black should run the fan, the blue the light. When I turn on the fan without the light...
You really should have an electrician look at it however make sure the lamps are not installed when you are connecting the lamp sockets and also check the voltage across the two leads you are connecting the lights to. Should only be 120 volts. There could be another issue that you are over-looking and that is why I think you should have a licensed pro come and take a look.
May 23, 2017 | Broan-NuTone N-763RLN Combination Light...
We have 2 identical fans in 2 different bedrooms. I had an aircompressor going and my daughter was running a blow dryer and it blew the breaker. Now both fans don't run, but the lights work. ?? the black...
Do me a favor, prior to reading on any further; did you try pulling (or turning) on the fan chain? As simple as this sounds, I've experienced this before. And I'd rather you try the simple solution first, before opening up the fixture. Okay, if that didn't work - the first TURN OFF the light switch or circuit breaker before working on these fixture's. If you're not well schooled in doing electrical work, I'd advise turning the circuit breaker off along with the wall switch. Now, when you open up your fixture, the black wire should be hooked up to the fan motor(s) lead wire; and the blue wire to your light(s) lead wire. Now, if both your fan and light were working before, then the wires at the fixture (black/motor and blue/light) were wired together. If so, then it could've blown both motor(s)? But I don't believe it did. Now that you've checked everything out, and your ready to turn the fixture back on. Keep the wall switch in the off position. Then go turn on your circuit breaker. If everything holds, then turn the wall switch on. It's done in this manner for safety reason's. Try this, and then let me know how it went. You should be good to go. Good Luck, and feel free to contact me again if you have any problems. Jim
Mar 16, 2010 | Hampton Bay 52 In.Carriage House II in...
Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter 28096 Westminster 52" Ceiling Fan with Light Logo
197 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
