Question about LG LSC26905TT Side by Side Refrigerator
Ice maker does not make ice. Water supply works, but ice machine is dry.
Our ice maker isn't making ice. It's putting water in it but will not dump ice out to make more ice.
Posted on Aug 05, 2012
We had problem of ice maker not working. It has been solved by keeping the refrigerator temperature around 38 degrees. if you keep the refreigerator at 33 degrees it seems to freeze the water line
Posted on Nov 26, 2009
  • 20 Answers
If it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Posted on Nov 12, 2009
    President:
  • 3,433 Answers
Is there water filing the ice tray? Make sure the tray is engaged and the full lever (wire on mine) is not locked in the raised position cancelling the ice maker. There is the posibility of the timer motor being at faullt. Listen for it's functioning. If the ice bin has frozen water in it, the timing is off and the water is not filling the tray properly .
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 55 Answers
SOURCE: ICE MAKER AND WATER SUPPLY DOES NOT WORK
Try emptying the ice bin. The ice cubes may have frozen together. Anbd the water line may have frozen. Try turning the unit off for awhile to defost water line.
Posted on Feb 19, 2008
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
  • 489 Answers
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Posted on May 11, 2008
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
Water keeps running and the ice maker isn't making ice
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
Jun 29, 2014 | GE Monogram ZDI15C Automatic Icemaker
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
Leak on the ice maker water supply
Good day,
The house water supply is connected to a dual water valve on the bottom rear of the machine. It splits there going to the ice maker and water in the door.
If the ice maker side is feeding water to the ice maker even though the ice maker is in the off position means the diaphragm in the valve is leaking and must be replaced. Very common problem.
Apr 11, 2010 | Refrigerators
Icemaker does not work
if the ice maker cycles but is not getting water check the water supply valve that supplies the water to the machine it split and sends water to the door and the ice maker that side of the valve that goes to the ice maker could be bad you can test it with a 120 volt line cord plugged in the wall plug to that side of the water valve if it works with the hose disconnected it may be a blockage or frozen line to the ice maker
Apr 09, 2010 | Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
We have a Frigidair Model FRS23HF5AQ4 with ice maker. Our water was off for about 12 hours and now the ice maker is not working. In the past when this occured I turned the freezer section off for several...
your ice maker needs to be changed out that happens when the water is off and the unit is still plugged in the maker runs in a dry mode too long and stops working
Jan 15, 2010 | Refrigerators
Ice maker not producing ice. Changed the water solenoid valve and the ice maker. still no ice! what is the problem here. how can i remedy this.
Good Day,
Obvious but,
Shut water off to house at the meter. Remove supply line to water valve. Place end in a bucket, have someone turn on main valve for a 15 second count. Should have a hard steady supply from the line into the bucket.
If no joy, and this is common,
Remove Ice maker and see if ice has built up in supply tube from outside back of machine into the rear of the ice maker.
If iced, defrost, but caution. Heat guns, hair dryers ect. can do more harm than good. Go slow.
I do not recommend heat because of all the plastic and vinyl. Just shutting down the machine by unplugging it, and air drying.
P.S. I've installed brand new ice makers and valves that didn't work out of the box.
Nov 18, 2009 | Kenmore Refrigerators
Not making ice
need to check your water supply...if good then see if ice maker has water in the maker itself. if not then replace ice maker
Jun 22, 2009 | Freezers
The ice machine is no longer taking in water to make ice
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Mar 13, 2009 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
763 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
