Question about Intertherm P3RC-030K Air Conditioner
I need an installation instructions for a
I need an installation instructions manal for a intertherm model # e2eb-015ha
    President:
  • 1,515 Answers
Hi, This is a very popular unit. Call you're local wholesale a/c parts house with all of the info on this 2 1/2 ton unit, and they can help. Have you tried going online to search for this? Would also try this. Good Luck,
Shastalaker7
Posted on Nov 12, 2009
Intertherm e2eb 015ha
let me guess.....its electric, right? could be so many things! do this first. turn power off. check all wiring for burnt or broke wires., usually at connections. next turn system on. does blower stop running and then breaker trips? if so its blower motor or blower relay. if blower and wires are ok then problem is probably a broken heating element.
Jan 25, 2014 | Heating & Cooling
Intertherm electric furnace model E2EB-015HA. Upper element will come on and run continously in 20 degree temp, Lower two elements don't come on. What's up?
Sounds like one or 2 stages of the sequencer is not kicking the other elements on. -OR- the limits ie klaxon switches in series with your elements are stuck open.
Dec 08, 2013 | Heating & Cooling
Model e2eb-015ha elements cycle on and off, but blower motor never comes on;a/c side works fine
R u saying that the blower motor works for the AC but not for the heat. If thats the case then u have a t-stat or control board problem. u can jump the red white and green wire from the tstat. if that works then then tstat needs to be replaced if not the control board is the problem.
Oct 21, 2011 | Intertherm P3RA-048K Air Conditioner
Model# E2EB-015HA is blowing cold air instead of heat.
do you have a call for heat from stat. spark ign/ glow coil test glow coil ohm should have rest./ spark ign-do you have sprk try turning off power turn back on if unit fires/ a saftey has shut you down find problem im assuming you have working knowlege of systems never bypass a saftey. hope this helps
Dec 29, 2009 | Intertherm P3RA-048K Air Conditioner
My Intertherm E2EB-015HA leaks and keeps shutting down
I would not blame the manufacture sound like the clowns that installed it. Tom
Jun 23, 2009 | Intertherm P3RA-048K Air Conditioner
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Heat comes on fan does'nt
diagram sould be on the back of the cover panel over the sequincer and relays
Dec 10, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm heat coils won't stay off until breakers off,thermostats are off
it is the heat sequencers. it happens all the time. replace them wire by wire to keep it simple. they are located behind the metal next to the breakers they look like this: cdf7518.jpg
Oct 19, 2008 | Intertherm P3RA-024K Air Conditioner
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Intertherm P3RC-030K Air Conditioner Logo
227 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
