Question about Marvin Portable Electric Radiator Heater
I HAVE A MARVIN 750/1500 QUARTZ TOWER HEATER. WHEN YOU PLUG IT IN IT MAKES LOUD VIBRATING BUZ-LIKE A DEAD SHORT.DISMANTLED AND PUT A AMP METER ON ONE LINE AND IT PULLS O CURRENT. THE NOISE SEEMS TO BE COMING FROM A SMALL RELAY MFG.BY TOWER MFG. ONE LINE OF POWER CORD IS HOOKED TO IT. IF THIS IS THE PROBLEM WHERE CAN I PURCHASE ONE? THIS HAPPEN LAST YEAR AND WE PUT IT A WAY, TRIED IS THIS YEAR AND IT WORKED FOR COUPLE WEEKS BEFORE IT STARTED AGAIN.
  • 1,608 Answers
Likely a simple switching relay. Doesn't need to be the same one, just needs to do the same thing, AND be energized as well.
Posted on Jun 24, 2017
3 Suggested Answers
  • 10 Answers
SOURCE: Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Posted on Jan 07, 2010
SOURCE: the rotary switch off/750/1500 is bad. Marvin 2060
replaced the rotary switch with a double poll single T. this makes the heater a 1500 watt with no 750 watt option.
Posted on Feb 08, 2010
Is it safe to plug a 1500 watt Marvin quartz radiant heater, model 4940 into the same receptacle as a lamp with a 100 watt bulb ? We had both appliances plugged into the wall and started smelling smoke...
You had a low end cheap receptacle more than likely or possibly a loose wire on the receptacle. You should have #12 wire fed from a 20 amp breaker and a 20 amp spec grade receptacle.
I am a licensed electrician with 30 years experience. IBEW LU #479 Beaumont TX.
Nov 19, 2010 | Marvin Quartz Radiant Heater
Dec 12, 2009 | Marvin 2060 Compact Heater
My Quartz heater is making a buzzing noise, what could that be?
The buzzing noise was coming from the back of hte unit on the lower left side. It may have been a "stuck" switch & tapping on the side seemed to fix it.
Nov 25, 2009 | Marvin Quartz Radiant Heater
The heating elements are burnt out. where can I
try this web link look for quartz tubes.
http://www.infraredheaters.com/quartz1.htm
Oct 14, 2009 | Marvin Quartz Radiant Heater
Nonheating marvin, model 5000, quartz heater
Yes, I got my Marvin, model 500 quartz heater fixed, thank you. Please discontinue further communication.
Nov 29, 2008 | Marvin Quartz Heater With Built-In...
Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
Nov 23, 2008 | Marvin 2060 Compact Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Marvin 5460
Returned to home depot. Fan was broken.
Feb 08, 2008 | Marvin Quartz Radiant Heater
Marvin 2020 Heater
try this place - they have replacement quartz elements maybe you can find one here.
http://www.infraredheaters.com/quartz.htm
Dec 10, 2007 | Marvin 2060 Compact Heater
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Heating & Cooling Logo
49 people viewed this question
Top Marvin Heating & Cooling Experts
Daniel Gasser
Level 1 Expert
Oloyede Monsuru
terry stevens
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
