Question about Dometic RM2652 Refrigerator
We have a 3 way Dometic fridge in our caravan. Have lived in the van for last 12 months ( grey nomads) have had no probs until trip home this week from Yulara to Victoria. Pulled up at night and freezer was starting to defrost & fridge not real cold. ( 2 door fridge). For two days fridge did not want to work. Got freezer part to work on gas. Now today the whole things seems to be back working on 240 volt. Does anyone have any idea what the problem is???? BTW we think it is something to do with the hot weather on the trip. Any comments would be appreciated.
  • 909 Answers
Temperature does play a big part in the efficiency of the fridge. The condenser at the back of the fridge needs cool air flow to allow gas vapour to be converted back into a liquid.again.
Posted on Nov 12, 2009
Testimonial: "Tks Guru, BikerT. To prove that you are right - since the weather/heatwave has gone - a nice cool morning today and I have frozen milk. Cheers, "
Ours has done the same thing except it seems to quit when we go to a colder place and works fine when we are in a warmer place. Worked great in Texas with 100 degree temperatures. Did not work in Grand Canyon area with temperatures in the 60's & low 70's.
Posted on Sep 17, 2013
Dometic fridge not working on 240 volts gas ok and 12 volt ok
The AC heater element is most likely open. Replace it and it will restore AC operation.
Sep 21, 2016 | Dometic Refrigerators
Gurgling when engine is turned off
2005 Grand Caravan 2 Problems may be connected - DodgeForum.com
dodgeforum.com/.../dodge-caravan/328382-2005-grand-caravan-2-prob...
Jun 12, 2012 - Vehicle: 2005 Dodge Grand Caravan ... I noticed last week that when Ishut off the engine I could hear water bubbling on my side of the van. coolant vanishing and gurgling
Jul 20, 2013
coolant leaking into heater core?
May 13, 2009
More results from dodgeforum.com
chrysler - Bubbling sound from the cooliant area when I turn ...
mechanics.stackexchange.com/.../bubbling-sound-from-the-cooliant-area...
Aug 13, 2014 - I hear this bubbling sound when I turn the engine off. It occasionally ... When the engine is hot and the coolant is boiling, open your hood and have a look around. DO NOT try ... 2005 chrysler neon clunking noise from front end.Missing: dodge
Mystery of the Gurgling Heater Core - YouTube
? 7:04
https://www.youtube.com/watch?v=db2nR0EMOIs
Dec 28, 2015 | 2005 Dodge Grand Caravan
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Is the 12 volt lights and fridge usually run off the same 12 volt cable?
fridge runs off 12 volts regardless or LP but need 12 volts to run
Sep 09, 2014 | Dometic Refrigerators
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
Dometic RV fridge will not stay on while traveling
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 22, 2010 | Dometic RM2652 Refrigerator
Dometic fridge. cooling it while traveling
If the trailer have good shocks absorbers, is posible traver with the unit on 12volts conection.
Aug 11, 2009 | Refrigerators
RM4236 tripping site electrics
Paul;
Are you tripping the shore power pedestal? If so did you unplug the fridge and try it. The park pedestal breaker should be at least 30 amp and I can not believe the fridge would trip the site breaker before it tripped the breaker in your caravan. Are you sure it is the fridge? Your fridge is an old eletrolux dometic and I can not find the manual in my files. You may call Dometic and get a manual but That will not help you much. I will be more than glad to resolve your problem but I need more info.
The Dometic# is 800 366 3842. Prompt to tech dept.
Repost to us
Thank You for using Fixya
Jerry
Mar 26, 2009 | Electrolux Refrigerators
Dometic RM2652 Refrigerator Logo
691 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
