Question about Frigidaire FRS26KF5C Side by Side Refrigerator
Frigidaire Side by Side no power to door. It makes ice but I can't get the ice or water to come out of the door.
  • 20 Answers
There are 2 boards I think in the door. Replace them
Posted on Nov 12, 2009
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Oct 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
No ice and no water
Does it make Ice OK? If so the ice-water valve may be at fault if neither work.
Eliminate water filter or frozen line to reservoir.
Make sure you have water to water valve
Shut off water, remove line, open water line. Catch water in container and examine. Clean on particles let it flush out some more open and close til clean. Verify pressure and flow.
Still no water?
Check voltage with a volt meter at the fill valve behind the refrigerator.
Attach volt meter to the coil wire plug just insert probes into them. Then push the button on the door like your getting water. No volts? If has Ice maker pull off the other set of wires on water valve and recheck with door switch. Still no power? Problem in the ice - water door relay or control board.
If these check OK water valve is not opening when power applied replace water valve. Power shows good replace water valve.
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
FRIGIDAIRE SIDE BY SIDE FRS26LF8CSN ICEMAKER NOT DISPENSING WATER FOR ICE MAKER
alkimike;
I had a problem with my icemaker not drawing water or making ice, I did a full defrosting of my freezer taking everything out leaving the door open for about 1.5 hours It appeared that the inlet water supply had an ice blockace up in the water outlet, defrosting it cured the problem, it has been workinf fine for the last day tub is full of ice!!
Jan 28, 2009 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Frigidaire FRS26KF5C Side by Side Refrigerator Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
