Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice tray won't flip over,water keeps coming inoverflowing tray
  • 126 Answers
Is it not turning, or is it turning and the ice isnt coming out? There is a small heater on the bottom of the ice tray to allow the ice to come out when flipped. If not flipping, the timer on your icemaker isnt working.
Posted on Nov 12, 2009
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Just installed a new ice maker. It won't turn on. Any suggestions? Does it take a while for it to come on?
Do you have the water turned on to the unit? Did you hook the power line up? Is the control arm in the down position? Then you will have to wait and see if it makes you some ice - MAKE SURE YOU DUMP THE FIRST DAYS ICE OUT WITHOUT USING ANY OF IT!
It does take time for everything to sync up together. And for water chiller to reconnize that you now want water to fill the tray. Don't worry, the first few trays of ice can be heard, so you don't have to keep opening the door and looking.
Jun 04, 2011 | Refrigerators
My ice tray moves fine and makes ice but for some reason it won't release the ice when it turns. Then the water tries to fill up over the full tray and makes a big mess. Any suggestions?
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
Jan 11, 2011 | Samsung RS2534 Side by Side Refrigerator
The ice maker in my samsung fridge is putting too much water into the ice tray thus dripping water into the ice compartment and freezing all the ice cubes together and dripping through the outlet
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray is supposed to catch the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
Jul 17, 2010 | Samsung RS2578BB Side by Side Refrigerator
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice tray will not fill with water
you have a bad mixing valve on the back of frig your model should have a duel valve one side for ice maker one side for water replace this valve you will be good to go
Jan 28, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Ice tray wont flip
check the very back of the ice maker and see if the piece that holds the rear portion of the ice maker has broken into little pieces causing the tray not to flip. the piece costs around 12 dollars and should be available for the unit that you are talking about. Thanks for using FIxYa and please don't forget to rate the solutions when thru please. Tahks again and have a great 2009!
Dec 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice Maker not flipping
May very well be a stripped gear in the drive unit. Unplug ice maker and remove mounting screws. Out of the freezer remove front cover and inspect drive gears for damage. Replacement gears should be available through a dealer for you make and model number.
May 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
65 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
