Question about Rti Technologies Rti T1 Remote Control
What does it mean when the light at the top of the remote is red instead of green?
    Problem Solver:
  • 9 Answers
The red indicates low battery. The batteries are estimated to last around 2 years at that point or later the battery will weaken and the red light will show up more often. In some rare cases the red light will not go away even with a fully charged new battery, in that case there may be something wrong with the charging circuit inside the remote that gives feedback on the battery's charge. You can either live with a false reading of the battery level and charge the remote nightly OR you can send it to RTI for a repair.
Posted on May 11, 2010
    Problem Solver:
  • 6 Answers
It means your battery is almost dead. It could be because the charging cradles RTI released are designed to fail.
My advice is to not buy RTI products. They do nothing for customers that have multiple RTI products in their home.
Posted on Apr 28, 2011
Red light on not green
helllllo.........red lite......[a] red lites means during the update if it lite red remove the thumb drive from the system ,unplug it from the wall outlet one minute +..then plug back in.make sure the system is power on[ showing green led] insert thumb drive....if problem persist call bose @ 1-877-335-2073us/1-877-701-2175canada.......bose-on see me on amazon for bose remotes bookbundler
Sep 01, 2014 | Bose Solo TV sound system - Black
My bose solo has a yellow light instead of green
The yellow light means you are in reduced bass mode. Hold the mute button on the remote for about 3 seconds and you'll hear 3 tones going up and the light will switch back to green. Enjoy!
Mar 01, 2014 | Bose Solo TV sound system - Black
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
What does a red light for powerline activity mean?
It indicates your line quality for the Homeplug - Green: Best, Amber: Better, Red: Good
Details here http://www.zyxel.com/uk/en/products_services/pla_401_series.shtml
Jul 16, 2012 | Zyxel PLA-401 v3 - Bridge - Ethernet, Fast...
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Converter wont work red light on when i use the remote it wont turn green when i push the red button manualy it still wont turn green
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Aug 05, 2010 | Apex Digital HT-150 System
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
LED lights for locking and unlocking flash at the same
that system is part of D.A.S. 2( driver authorization system verson 2). the lights in the mirror will blink red when lock and green when unlock. during the self diagnoses portion they will blink simutanilusly when the remote key batteries are low and alternating when there is a malfunction with the key or other part of the driver authorization. it sounds like your remote key central locking batteries are low.
Apr 15, 2009 | 1995 Mercedes-Benz C-Class
TV won't turn on
The red light instead of green is an indication that theres a voltage missing or an improper voltage in the sweep or main power supplys. This should be handled by a trained service tech. Good Luck
May 28, 2006 | Durabrand DWT2704 TV
Rti Technologies Rti T1 Remote Control Logo
1,316 people viewed this question
Top Rti Technologies Televison & Video Experts
Tom Chichester
 Grubhead
Grubhead
Are you a Rti Technologies Televison and Video Expert? Answer questions, earn points and help others
