Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I need help replacing a Kenmore Elite Water Filter - 46- 9010
I am replacing a Kenmore Elite Water Filter - # 46- 9010. I would like to know which direction the filter should be in before I rotate it 1/4 turn to the left. Do I insert it horizontally and turn it so it ends up being vertical? Or is it the reverse? Thank you for your assistance.
Insert it so it is vertical and then rotate one quarter turn to the right so it is now horizontal nad the line matches the grill on the front of the fridge.
Posted on Jan 27, 2010
  • mjveith Nov 26, 2013
    also only use the Kenmore filter, no off brands. They will eventually leak and cause all sorts of damage to your kitchen floor!
Can't close the door on the water filter cabinet on my Kenmore Elite refrigerator
check to be sure you have the correct length filter in place, you may have one to long for the unit.
May 30, 2015 | Kenmore Refrigerators
Have a Kenmore Elite Side by Side and there is water running down the side of the fridge which appears to be coming from the water filter. Already changed it twice.
Did you flush the system after changing the filter? Air can cause water to leak if it not flushed after each filter change. It takes about 6 to 7 minutes to get all the air flushed out. I hope that helps...
Nov 12, 2014 | Kenmore Elite Side By Side Refrigerator -...
We keep getting an f35 error on our Kenmore Elite front load washer. Even when we try to restart the load (no soap to rinse it) the SUDS and f35 errors come up. Any suggestions? I don't see f35 in the...
First of all, be sure you are using only HE detergant. Your drain filter is likely clogged and needs cleaned. On the front lower panel of the washer, remove the screws and panel. You will see a drain filter (about the size of a tennis ball). Before removing the drain filter you are going to need to hand bail the water out of your drum or all the water will run out when you remove the drain filter. Slid a plastic trash back up under the drain filter to help contain whatever water you could not bail out by hand. Remove the drain filter and clean it thoroughly. Replace the drain filter, replace the lower front panel and run a rinse and spin cycle. If sudsing error continues and you are using HE detergant, you may need to lower the amount of detergant you are using. However, 9 times out of 10, it is just the clogged drain filter.
Nov 26, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE 3t keeps flashin the F02 error code i cleaned the hose that dispenses the water and the connection to the hose but the problem continues can you help me
u might have a drain problem u need to take the front panel off at the bottom there are 3 t20 torque bits take them off and the water pump should be in front or to the right side theres a filter for the pump u need to take that of and see if there is any objects in the filter if so clean it out.then check your drain two if this does not work u might need to replace the pump good luck
Feb 15, 2010 | Kenmore Elite 45986 Front Load Washer
Can't identify "water filter indicator light"
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
Dec 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Need to clean my filter on Kenmore Elite he3t--where is it?
FIRST GET ALOT OF TOWELS MACHINE HOLD 3 GALLONS OF WATER STILL THERE IS A PLASTIC PUMP W/ ROUND HANDLE REMOVE HANDLE COUNTER CLOCKWISE AND REMOVE WHATEVER IS IN THERE
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite water filter
just leave your filter installed
Dec 11, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
406 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
