What pin setting do you use for setting up a slave drive on WD?
Http://www.telecommunication-distribution.com Go to that website and they will send you free diagram for your Hard Drive
Posted on Nov 12, 2009
How do i make a wd5000aakx hard drive a slave drive
http://www.wdc.com/wdproducts/library/other/2579-001037.pdf
Jul 11, 2015 | Conrad WD HDD 500GB SATA 3,5" WD5000AAKS...
Don't know how to set jumpers for master and slave
These jumpers you're referring to normally are spoken of when dealing with a CD/DVD Drive or a hard drive. Usually it's an older one too. They look like this...
You'll need to look on the device itself. There it will have labeled which pin set is for slave or master. Just move the jumper to the correct pins.
Mar 13, 2011 | Computers & Internet
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
Need jumper settings wd800 as Mast. & maxtor Dia.plus as slave??
To use the WD 800 as a master there must be no jumper attached to it.The maxtor has a diagram for the jumper and it MUST be set to slave not cable select.
Mar 24, 2010 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
I need to know how to make model WD102AA-53ANA0 a slave. I am trying to move information on this hard drive.
Generally on a WD the center two pins is where the jumper goes for master with slave present. WD drives usually have it etched in the plastic SL, MA,CS.
Nov 30, 2009 | Computers & Internet
80 GB WD hard drive being used as master with windows xp when used once as slave with other WD hard drive, when tried to use it again alone or as master is no more bootable, but only as slave it is ok, I...
u ll have a jumper which is located at the back where u hv ur power supply pin.. there u ll hv one pin with 6 needles on which a plastic jumper ll be there only on 2 of the six needles. that plastic jumper may be in slave mode do remove the jumper and place it in master mode.....
thnkyou
Jun 29, 2009 | Western Digital Computers & Internet
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
Apr 26, 2009 | Western Digital Caviar WD200BB 20 GB Hard...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
