Question about Remington 12 Amp 215 mph 14:1 Mulch Ratio Titanium Mulcher Blades Electric Blower / Vacuum / Mulcher #BV12200AT
Tolerances...?? The upper and lower vacuum tubes don't fit together. The vacuum bag adapter doesn't fit properly on the blower/vac. Otherwise the unit is a dream.
How to repair Toro Super Blower no longer blowing, only vacs/intakes?
when you remove the vac part there should be another "grid type" part that snaps in place of the vac tube. This engages the safety switch and keeps your fingers out of the impeller.
Oct 05, 2014 | Toro 51592 Super Blower Vac 3-In-1...
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
How do i change the fill tube
Cut the old fill tube from the lower housing and remove the top adapter from the old tube. Clean the bag and housing to be sure the spout the tube attaches to is clean. Be certain to use the fill tube used in the Generation 3 and 4 models which has a wire in it. Wet the lower few inches of the tube and screw it fully onto it's base in the lower housing. The upper adapter can be attached with cable ties.
Jan 05, 2011 | Kirby G4 Bagged Upright Vacuum
How do I convert from blower to vac
First, remove the blower tube. Then connect the collection bag on the blower tube outelt. Then open the bottom fan cover. Keep it open and connect the vacuum tube into the opening.
Dec 05, 2010 | Craftsman 225 Mph Electric Blower Vac
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
I have a Craftsman electric Blower/Vac with no operatorers/instruction manual. I would have liked to use the vac option but have no idea how to couple the pipes together and attach the bag for this...
For maybe getting a manual, go to:
http://www.manualsonline.com/
You will find that you open the bottom vent, put a large suction tube in the recess and remove the blower tube and attatch a collection bag on the housing that held the blower tube. That's all there is to it.
Aug 13, 2010 | Craftsman 4 Cycle Blower/Vac
How do you put it together for mulcher
Undo the spring loaded cover on the very bottom of the machine, insert the vacuum tube for mulching in there and then attatch the catch bag for the mulched material to the outlet where the tube for the blower was...simple as that.
Jul 04, 2010 | Craftsman 12amp Electric Blower with Vac...
I can't find my manual for my leaf blower and i want to go from blower to vacuum! it is a model # 358794730. thanks!
on the bottom there is a slot were you have to stick a screw driver in to release a clasp. once you release the clasp the door swimgs open and your vacuum tube fits right in. then take the blower tube off and hook your bag up in its place. let me know if you have questions about my answer, thanks
Nov 05, 2009 | Craftsman 4 Cycle Blower/Vac
How do we activate blowing system on the blower/vacuum? I don't know how to switch from vacuum to blower?
1) the pick-up tube for vacuum is removed
2) the vac bag is removed and blower nozzle is installed in it's place
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
Remington 12 Amp 215 mph 14:1 Mulch Ratio Titanium Mulcher Blades Electric Blower / Vacuum / Mulcher #BV12200AT Logo
46 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
