Question about Canon imagePROGRAF IPF710 Printer
When we print with out IPF710 with the print quality set on "high", it does just fine. But when we set the print quality to "standard" it prints parallel pink lines that are about an inch apart across the page. How do I correct this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
Try to print a nozzle check from the test print menu and check if the 6 grids are correct.
From this print out you will find out if some of the colors are nto correct
Posted on Dec 29, 2009
  • lidia178 Jan 18, 2011
    I've done the above and noted that the Cyan grid didn't print correctly - how do I fix this??
Print Job Keeps Cancelling
your computer may not be able to provide that high of a resolution to the printer. It would be like trying to take a color picture with black and white film.
Apr 17, 2014 | Epson WorkForce WF-3540 All-in-One Printer...
Printing of canon s400 poor quality on my computer but prrint fine on other computer
under printer driver properties on your computer,under print preferences, check the print quality settings. i.e if the quality is set to draft change to high.
Aug 23, 2011 | Canon S400 InkJet Printer
Pixma mx330 printing very faded colors
try selecting higher print quality setting. If it still prints faded on "standard" or "high" quality, try running the "printhead clean" or "deep clean" utility (under "maintenance" in printer properties).
If still no good, refill or replace cartridge(s).
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Does the Epson Stylus Photo R340 Printer print non photo documents in plain text?
yep, these photo printers print text aswell, just designed to give a better quality photo print
Dec 03, 2009 | Epson Stylus Photo R340 InkJet Printer
Streaks on copy
Try these steps first:
1. Check ink level.
2. Nozzle Check Pattern
  1. Load A4- or letter-size plain paper in the Auto Sheet Feeder (ASF) or cassette.
  2. Press the <Feed Switch> button to select the appropriate paper source.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Press <OK>.
    The machine prints a nozzle check pattern.
  5. Confirm the pattern is not broken, missing, or a specific color is not printed.
3. Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
You can also try using a higher quality print settings as follows:
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
If the above steps do not solve your problem, it may be a time to purchase a new printhead.
Oct 09, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Canon Printer IMAGE QUALITY
use the canon software and set up fax seperately.
Aug 05, 2009 | Computers & Internet
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Poor color when printing in high qualitiy - fine when in standard quality
go to preferences then clock on manual
slide pink slider 100%left
give a litle bit black to right
print light
Manual is the printers dark room
Feb 27, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Print Output Too Slow
It could be your print quality is set too high! Go to Printer and Faxes in Control Panel! Right Click on your printer and select properties On the General Tab click on Printing preferences! Look for something that Says quality or graphics or something like that! If its set to high quality then set it to normal If its set to normal then try draft!( but if you need to do this then there is an underlying issue!) Try this and get back to me! regards, babb
May 03, 2007 | Canon PIXMA iP4000R InkJet Printer
FD73 Photo Quality
I'm guessing, cause i own a F505 and not a FD73......but, I dont even see a use for the F505 "standard" quality setting. It will stay on "FINE" quality always. I've got a HP 882c and it prints just fine. I use HP premium photo paper and the printer setting BEST. Are you using photo paper? Regular paper will bleed the colors around. Take some pictures on FINE and print them out on photo paper w/ printer BEST and compare.
Sep 11, 2005 | Sony Mavica MVC-FD73 Digital Camera
Canon imagePROGRAF IPF710 Printer Logo
448 people viewed this question
old marine
old marine
