Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Fan has turned off. not cooling/freezing
Fan has turned off all the sudden . not cooling/freezing.
  • 20 Answers
Computer board in the back of the machine...repalce it...you will see the panel when you look behind the ref
Posted on Nov 12, 2009
My Haier compact refrigerator suddenly stopped cooling.i cleared ice buildup and returned power to it .waited 30 minutes and still not cooling.what can I check
Check if the compressor fan motor is engaging. If the fan is not spinning then the coil will freeze up again. Also check that there is enough air movement around the fan for circulation. This is also try for the inside fan. Good luck
Dec 13, 2016 | Haier Refrigerators
Compressor runs but fans dont.
If the compressor is running and pumping with no heat produced, you have lost refrigerant.. Most modern freezers have a controlled fan so the coil can freeze before the fan starts.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Dell laptop periodic buzzing
Sounds like a bad bearing or dust accumulation in the CPU heat-sink fan. If the fan does not cool properly the CPU will overheat and shutdown or freeze the computer.
Jan 29, 2013 | Dell LATITUDE Computers & Internet
It's forming ice
The condenser, cold coil, is getting too cold, "freezing up. Usually this is because the small tube that comes out of the temp. control is not in good contact with the coil. This problem is aggravated if the fan is run on too low a setting. To clear the problem cut off the cooling and just let the fan run. The warm air will eventually melt the ice and you will suddenly start getting a much larger volume of air flowing. Now turn on the cooling cycle and try operating the blower at a higher speed.
Oct 04, 2012 | Heating & Cooling
Heater blowing hot then suddenly blows cold and engine overheats. Intermittent problem. After engine cooled may overheat again with heaters blowing cold then suddenly heater blows hot again and...
I have written a tip on this.
You may have a couple of problems. I would first replace the thermostat, and make sure you have the proper coolant(ant-freeze) level.
Please let me know how it goes and if you need further help I am here.
Feb 09, 2010 | 2002 Toyota Celica
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Older Superior Brand Kegerator Freezing
Sounds like the fan can be running backwards. I'm not sure of you exact model, but it has to match the air flow of the original unit. Do you remember? Some manufacturers use reversable motors and are some what easy to reverse.
Good luck and hope this helps.
May 08, 2009 | Danby DKC645BLS Compact Beverage Cooler
Refrigerator stopped freezing & cooling
can you hear compressor working
Apr 05, 2009 | Refrigerators
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
