Question about Whirlpool Calypso GVW9959K Top Load Washer
Our washer gets to about 23 minutes left and it comes up with LD. What does that mean?
  • 126 Answers
Ld is long drain time. Maybe you have something in the drain pump or stuck in the drain.
Posted on Nov 12, 2009
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Kenmore Oasis HE 27082 Displays "LD" error falsely
Since that you let repairman do twice and didn't fixed the problem, I think your washer have still warranty from the vendor. and they repair it free.
Please verify the panel board of the machine maybe got grounded in the wiring or got wet. How ever you can do that in your own you should consult the repairman on that matter. however the two repairman did not resolve, so its better to bring the washer's to the vendor. im sure they can fix the issue or you will be enlightened by their valuable suggestion and solution.
may this help
melnavz
Oct 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Showing ld code and wont drain or spin
Hello the LD code simply means "Long Drain"
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping.
Thanks
May 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Jan 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
LD error on Kenmore Oasis HE 27082
I had the same problem with F1 and F68. I just bought a $345 new computer for my washer. These machines are defective. Mine was purchased in Nov. of 2006 but not even out of the box until Jan. 2007!!!
Ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
Apr 15, 2008 | Kenmore Oasis 27042 Top Load Washer
Washer beeps Ld a few minutes into each wash
LD means = Long Drain
Problaby samething inside the pump
Is your machine calypso
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
