Question about Simac 4050 Il Gelatao Magnum 1 Quart Ice Cream Maker
Not churning corectly
The instructions say the average churn time is 20 min. and at that point the blades will stop to identfy that the churn cycle is complete. Unfortunately the blades locked up at 5 minutes and the bottom 1/2 in. was rock solid and the top 2 in. was soup, not even soft serve. I pre-chilled the unit for 10 minutes empty. I have some experience in making ice cream so I have a good idea of the process. This wasn't agitating the mixture enough to pull the cold off the bottom, although it looked like it was working perfectly until the 5 minute mark. The curn blades look like they are riding just off the bottom, Ideas?
This sounds like a low on charge condition which you probably won't be able to repair yourself unless you are a refrigeration technician. There is a possibility that the cooling fan is not operational or the condenser is dirty. Two things that are very easy to check. First check the temperature of the tubing going to and from the compressor. Both will be hot if this is your problem. Blow out the condenser with compressed air. If it is greasy, use a cleaner. If the fan motor is not running, check for voltage at the motor. If there is no voltage check the switch and wiring. If there is replace the motor. If everything is clean and running the tubing from the compressor to the condenser should be hot to warm and the outlet around room temp. Run your fingers down the side of the condenser from the inlet. If it is cool after the first tubing bend, it is low on charge most likely and is probably not worth repairing.
Posted on Nov 24, 2009
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
Discovery kids ice cream maker instructions
Usually with these cheaper ice cream makers you put the bowl in the freezer for 12 hours and then put it on the machine and turn it on . Very important point turn it on so it is churning. Why so that what ever you pour in doesn't freeze solid and stop the agitator from churning. Most ice cream is Cream and sweeten condensed milk and flavouring. I do not have this exact ice cream maker but the one I do have has made three different ice creams in it so far. Add 1000 mL of cream to 250 mL sweeten condensed cream. Watch it for about 20 minutes till ice cream is solidifying then transfer to an plastic icecream container and put in freezer for at least 4 hours.
Aug 19, 2015 | Ice Cream Makers
Cuisinart ice cream safety feature
10 MINUTES IS NOT LONG ENOUGH, PLEASE WAIT FOR AT LEAST 20-30 MIN'S
May 18, 2012 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Just receive this machine and am not sure which switch is the chill land which switch is the churn!
Simple. The churn button is the one with the swirl on it (i.e. indicating churn). The chill button just looks like a snowflake.
Jun 25, 2010 | Musso Lussino Dessert Maker 4080 1.5 Quart...
Cuisinart MM-2 Mini Mate Chopper/Grinder - Instructions
In order:
Yes, you must twist off base to remove blade - only twists one way, not the other
Yes, instructions online/manual:
http://www.cuisinart.com/share/man/72_man.pdf
SRP - $79.00
Current Price - about $40.00
Orig manufactured 2003, but the first # in serial # will tell you your exact manuf. year, 3 = 2003, 4 =2004 etc
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Blade stops turning but motor still running
Hi Lew 2!
Sounds like the belt might be slipping prematurely. I'd try cleaning the belt and all the pulleys with an alcohol based solvent or rubbing alcohol (clear) to remove any excess oils that might cause slippage and see if that helps Is there any type of belt tension adjustment? If so, also try tightening the belt.. If the problem persists, you probably need to replace the belt.
If this helps, after the churning stops, remove the paddles and cover the top with plastic wrap or wax paper and allow the mixture to "firm up" in the ice bucket nother 10-15 mnutes, and then enjoy a great old-fashioned treat!
Hope this is a help, let us know how it goes, and good luck!
-WB
Jun 14, 2008 | Simac Ice Cream Makers
Instruction manual
Can I have the make and model of the ice cream maker please?
May 07, 2008 | Back to Basics ICM32 10-MInute Ice Cream...
Problems with "easy-lock" lid
i noticed that the lid doesnt neccessarily "lock" into place, rather sits in there, next to those tear drop looking things.
Dec 06, 2007 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Simac 4050 Il Gelatao Magnum 1 Quart Ice Cream Maker Logo
246 people viewed this question
Top Simac Ice Cream Makers Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Simac Ice Cream Maker Expert? Answer questions, earn points and help others
