Question about HP Photosmart C6280 Printer
When i print multiple pages. and I tell it to print two sided. It prints odd numbers and then I have to keep changing the pages and putting them back in. Isnt it supposed to do it automatically?
    Sniper:
  • 70 Answers
In order for the printer to print on both side “automatically”, you need to have a device called a “duplexer” installed. Is a device that goes in the back of the printer (where the paper jam door is).
Assuming your printer has such device you can look into: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01086991&cc=us&lc=en&dlc=en&product=3194498 for more detail “activating” the duplexer.
Cheers,
Ed
Posted on Nov 14, 2009
Testimonial: "thank you"
How many pages in a pdf download for Necchi Instruction manual for Necchi Model 3101 FA?
when the down load opens up on the screen, in a small tool bar at the top of the pdf section there are areas that show page numbers , zoom in / out expand size etc the number of pages will be there shown as 1 /24, or 50,or 600 etc ( 1 / of the number of pages in the down load )
if you click on the scroll bar on the right of the page proper and scroll down , as you pass each page break it shows the next page number
if you scroll down the page you will come to a contents list and that will also show the number of sections in the manual and that will indicate how many pages you can expect
to reduce paper wastage from a normal house hold printer when you print from the printer logo in the bottom right of the page you get the printer up and where it says print all , change that to print odd pages ( or even pages ) or or print pages and this is where you put in the pages that you want printed -such as 1,3 5, 7 etc
when the print run is finished put the whole lot of printed pages turned around and back in the printer then print the page numbers that you missed on the first print run this will result in a booklet with printing on both sides of the page and reduce the number of sheets used in printing
Nov 07, 2015 | Necchi Sewing Machines
I want to print on both sides of the paper
The Brother HL-2040 machine does not have and cannot be fitted with a duplexer to print both sides of the page automatically. You can only duplex manually, that is - you turn the page over and put it back in the machine to print on the other side. Some settings will allow to print double sided manually, where the printer prints all the odd numbered pages then instructs the user to place ALL the printed stock back in the paper tray to then print all the even numbered pages.
Mar 09, 2014 | Brother HL-2040 Laser Printer
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
How to take back to back printing in canon LBP 2900
Here are the steps in this process:
  1. Go to File menu and then select Print.
  2. Print dialog box will come up. ...
  3. Click OK to print all the pages in document that have odd numbers.
  4. Once printing of odd numbered pages is done, flip the stack of printed pages and put them back in tray.
http://techwelkin.com/print-two-sides-paper-without-duplex-printer
Aug 21, 2012 | Canon LASER SHOT LBP-2900 Printer
How do I print double sided?
first off you need to tell your software (office word, or etc ) that you want to print doulbe sided, it will then open a dialog box where you would pick "print odd pages only" after those print you will take the paper out and reinsert it (opposite side) and then click print again, this time clicking on "print even numbered pages only" now your will have a sequence of pages that are like a book, with page 1 on the front, page 2 on the back, etc, etc.
Mar 20, 2011 | Brother MFC-9420CN All-In-One Laser...
I have printed all odd # pages from a document, but my HP Laserjet 4 won't feed these pages back through to print on the blank side with even # pages. I've tried to keep the front (feeding edge) of papers...
You need to try a thicker paper, Heavier stock to double print the page. Slightly more expensive. Recycled paper typically will not work for this type of function. I had this same problem and found this was the only solution.
Oct 31, 2009 | HP LaserJet 4 plus Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Print Odd or even pages only
There is no option in the printer to chose eve or odd pages bout if you print under windows environment you can do that from the able cation example if you use Microsoft world go to file chose printer then chose eve or odd from print comp box
Mar 12, 2008 | HP LaserJet 4050tn Printer
HP Photosmart C6280 Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
