Question about Cell Phones
Dont know how to dismantle the phone to install new didgitizer samsung m800 i can pop the screen off but the wires go behind the lcd screen i removed the screws from the back but i dont know how to unsnap it ''with out breaking it''
Sph-m800 forgot password
Hello My Dear:"":::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 17, 2013 | Samsung SPH-M800 Cell Phone
How to dismantle lcd of Neo Basic B3362n
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Nov 30, 2012 | Computers & Internet
The LCD screen on my Instinct is blank except for a few vertical lines. Can I fix it?
You can. you can replace the lcd screen yourself for about 30 dollars.
Check out the guide linked below:
How to Repair Samsung instinct M800 LCD Screen
Feb 18, 2010 | Samsung Instinct Cell Phone
Samsung Instinct Screen isn't working correctly
It sounds like the Samsung Instinct digitizer is bad, not the LCD screen.
You can replace it yourself for about 15 dollars. Check out the link below for a guide to replace it and where to buy the Samsung m800 digitizer
How to Replace Samsung Instinct LCD digitizer
Feb 09, 2010 | Samsung Instinct SPH-M800 Cell Phone Car...
Crack inside the screen
You can take it apart and replace the lcd screen yourself. Here is a link to a guide and video and a place to buy parts if needed.
Good luck
Samsung Instinct SPH-M800 LCD Repair Guide
Oct 25, 2009 | Samsung Instinct Cell Phone
Touch screen does nothing
Follow the guide below and just replace the touvhscreen. If you are under warranty, let ATT look at it first
Oct 17, 2009 | Samsung Instinct Cell Phone
My son some how locked my samsung m800 touch screen and i can't get it unlocked he does'nt remember what numbers he pushed
Go to mobile files dot com. find the newest driver off of google for ur device, ur donna need samsung pst for the m800. mobile files.com will have those ande click all the tabs liek feture settings, mms. ps u will need a usb cord to connect the device to ur computer. but anyways read the device with the program and u will find the lock code under the security settings also tri 0000, 1234 and the last four of the phone number if that dont work do what i suggest above. Ur welcome.And good luck
Oct 06, 2009 | Samsung Instinct M800 Black Rubberize...
Samsung sph m800
samsung instincts dont have sim cards.
Jun 05, 2009 | Samsung Instinct SPH-M800 Cell Phone Car...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
