Question about Kinyo Game Zone GZ-501 Computer Speakers
How do I install the 5.1 to a HDTV... it has 6 connecters, and do i use all of them?
    Guru:
  • 355 Answers
Try the user manual for help
other wise goto the company site
ok bye...........................................
Posted on Nov 12, 2009
Need info on how to change a 2000 Cadillac
REMOVAL PROCEDURE
TOOLS REQUIRED
A J 34730-1A Fuel Pressure Gauge
A J 39765 Fuel Sender Lock Nut Wrench
CAUTION: Refer to Batterry- Disconnect Caution in Service Precautions.
1. Disconnect the negative battery cable.
2. Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure. See:
Fuel Delivery and Air Induction/Fuel Filter/Fuel Pressure Release/Service and
Repair
3. Drain the fuel tank. Refer to Fuel Tank Draining Procedure. See: Fuel Delivery and
Air Induction/Fuel Tank/Service and Repair/Procedures
4. Remove the fuel tank.
5. Remove the fuel sender assembly.
6. Disconnect the fuel pump electrical connector (5).
7. Remove the fuel level sensor electrical connector retaining clip (6).
8. Disconnect the fuel level sensor electrical connector (7) from under the fuel sender
cover.
9. Remove the fuel level sensor retaining clip (4).
10. Squeeze the locking fangs and remove the fuel level sensor (3).
INSTALLATION PROCEDURE
1. Install the fuel level sensor (3).
2. Install the fuel level sensor retaining clip (4).
3. Connect the fuel level s ens oi electrical connector (7).
4. Connect the fuel level sensor electrical connector retaining clip (6).
5. Connect the fuel pump electrical connector (5).
6. Install the fuel sender assembly.
7. Install the fuel tank.
8. Refill the fuel tank.
9. Install the fuel filler cap.
10. Connect the negative battery cable.
11. Inspect for leaks.
11.1. Turn ON the ignition for 2 seconds.
11.2. Turn OFF the ignition for 10 seconds.
11.3. Turn ON the ignition.
Aug 29, 2014 | Cars & Trucks
Memorex MLT1912: Signal only coming through on two channels
Did you try setting and finding the other missing channels manually?
Jan 03, 2008 | Televison & Video
I connected my laptop to my LG HDTV 1080p but it gives No Signal and i don't know why. The cable is connected and the laptop is fully working!
What kind of cable? VGA? DVI? HDMI?
Did you use the combination keys, Fn and either F4, 5, 6, or 7 on your laptop (depend on brand) to select internal/external/both display functions?
Feb 11, 2011 | LG 42PX5D 42 in. Plasma HDTV
How do you do it--alterenator replace 2006 dodge van
Hi there, you did not specify the type of engine you use so here are possible guides for varying enginge types:
2.4L Engine
To Remove:
2. Disconnect the intake air temperature sensor and remove the air cleaner assembly.
3. Remove the EVAP purge solenoid and move it out of the way.
4. Disconnect the wiring from the alternator.
5. Remove the accessory drive belt from the alternator.
6. Remove the alternator.
To Install:
1. Install the alternator.
2. Install the accessory drive belt
3. Connect the wiring to the alternator.
4. Install the EVAP purge solenoid in the bracket.
5. Install the air cleaner and duct, then connect the intake air temperature sensor.
6. Connect the negative battery cable.
3.3L & 3.8L Engines
To Remove:
2. Disconnect the wiring from the alternator.
3. Raise and safely support the vehicle.
4. Remove the right front tire and lower splash shield.
5. Remove accessory drive belt.
6. Remove the lower engine oil dipstick tube bolt, then remove the wiring harness from the dipstick tube.
7. Remove the 3 mounting bolts.
8. Lower the vehicle.
9. Remove engine oil dipstick tube.
10. Roll and carefully remove the alternator from vehicle.
To Install:
1. Place the alternator into position on the engine.
2. Install upper mounting bolts to hold the alternator in place.
3. Lubricate the o-ring with engine oil and install the dipstick tube.
4. Install the upper dipstick tube bolt.
5. Connect the wiring to the alternator.
6. Raise and safely support the vehicle.
7. Install the alternator lower mounting bolt and tighten.
8. Install the lower oil dip stick tube bolt.
9. Install the accessory drive belt.
10. Install the right front splash shield and tire.
11. Lower vehicle.
12. Install the wiring harness at the dipstick tube
13. Connect the negative battery cable.
Hope these help.
Jan 28, 2011 | 2006 Dodge Grand Caravan
How do i connect my acer pc to my 42 in jvc hdtv
You have to purchase a good quality 3DFX video card to ba able to hook into TV
Jan 20, 2010 | Acer ASPIRE T180-UA381B DESKTOP PC
How do I get to the drivers side light bulb in a 2006 Chrysler Sebring Sedan? I have the replacement bulb and want to change it myself.
I will assume you are talking about the headlight?!
Removal
CAUTION: do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced life will result.
1) Disconnect and isolate negative battery cable.
2) Remove headlamp unit retaining screws. (bolts)
3) Remove headlamp unit to expose back of unit.
4) Disconnect wire connector from back of headlamp bulb.
5) Rotate retaining ring counterclockwise.
6) Remove retaining ring.
7) Pull headlamp bulb and remove from headlamp unit.
Installation
1) Install headlamp bulb to the headlamp unit.
2) Install headlamp bulb retaining ring.
3) Rotate retaining ring clockwise.
4) Connect wire connector to bulb.
5) Install headlamp unit.
6) Install headlamp retaining screws. (bolts)
7) Connect the battery negative cable.
More detailed info on how to get unit out.
Removal
1) Disconnect and isolate the battery negative cable.
2) Remove the two retaining screws.
3) Remove the upper fascia retainers by prying under the head of the fasteners with a flat bladed tool.
4) Remove headlamp unit from fender side first, then pull headlamp unit out.
5) Disconnect the wiring harness from the bulbs.
6) Remove the headlamp unit.
Installation
1) Connect wire harness to the bulbs.
2) Install headlamp unit.
3) Install the retaining screws.
4) Install upper fascia retainers.
5) Connect the battery negative cable.
I hope this will help you to get the light changed.
Jan 11, 2010 | 2006 Chrysler Sebring
Strandby power indicator flashes 6 times repeatedly
According to the symptom the problem is of thermal fuse which needs replacement, the part number is given below:
1-910-006-44
The method to change it, is given below:
1-Remove rear cover
2-Remove sub-woofer speaker box
3-Remove metal backing plate
4-Remove Exhaust fan
5-Remove Optical block screws
6-Remove Open thermal Fuse
7-Install new Thermal Fuse
8-Reassembly Connection & Wire-dress.
Act according to the instruction and it will solve the problem.
Thanks
Nov 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Kinyo Game Zone GZ-501 Computer Speakers Logo
88 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
