Question about LG VOYAGER VX10000 Cellular Phone
No sound there is no sound coming or going from my phone...it will ring, the alarm goes off but when touched it vibrates but no sound. Also during a phone call there is no sound coming in and the person on the other end cannot hear me either.
How can I make my speakerphone work again?
call someone or tun on music on phone menu select loud
Feb 27, 2016 | Cell Phones
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
I have the g2 touch and it works fine apart from the alarm clock only vibrates it plays no sound even when i changed the song and checked all my settings is this a fault?
if you set your phone on vibrate it will not ring unless u select a tone . when you set up the alarm make sure you select a tone for the alarm
Nov 13, 2009 | Cell Phones
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
HTC Touch Pro T7272 - Sound problem
go to htc.com and download the last rom for touch pro and it will be fine!
NB: I downloaded the arabic rom wich have two features
1- on the first Installingthe rom is english
2- As u can active arabic, you can also disable it if you are foreign users but it will be better to install it without acivating arabic (case 1-)
Link: http://www.htc.com/mea-en/SupportDownload.aspx?p_id=140&cat=2&dl_id=516
Jan 07, 2009 | HTC Touch Pro Smartphone
LG VOYAGER VX10000 Cellular Phone Logo
129 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
