Question about Samsung TV Remote Control
The source button does not give me the options for source.
Need code for 47 inch GFM tv for Jumbo remote
Posted on Nov 12, 2009
Where is the option button please
The Option button is here
http://www.carrierbid.com/wp-content/uploads/2014/01/options-button-300x300.jpg
Do you mean the button which gives you the option of where the signal comes from? This will either be 'Inputs', or 'Source' on the remote.
Jan 27, 2016 | Televison & Video
How do I switch the TV from cable to regular TV
Depending on your TV make, normally hitting the antenna button will switch you from cable to antenna (regular) TV.
Aug 24, 2015 | Video Game Consoles & Games
How can I set a tv to antenna mode in order to receive digital channels?
It depends on the TV. First make sure that the active Input is TV. On some TVs, you may need the original remote or an universal remote that has an Input or Source button (and a code that enables that function for your TV). Some TVs have the Input or Source button on the TV as well or a Menu option to change inputs.
Next enter the On-screen Menu and find a Channel or TV setting option. In that sub-menu, you will find a Source option. (It may give the choices of Air or Cable.) After you set that to the Air, you'll need to scan for channels.
Please add a comment with the model of your TV for additional assistance. I hope this generic comment helps.
Mar 10, 2015 | Televison & Video
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
I am trying to tune my Toshiba 26WLT66 analogue channels but can't get it out of DTV mode. I know this can be changed because I put it into DTV mode at our other house - I have since mislaid the owner's...
Hi there not sure if you have resolved this yet but I had same problem and managed to resolve it by chance.
If you press and hold the source button (arrow pointing to the centre of a circle) this will give you all your source options down the left hand side, including analogue.
Scroll down to ATV and select then tune using menu options.
Hope this helps
Mar 12, 2011 | Toshiba 26WLT66 26 in. LCD Television
After purchasing a PVR machine from Shaw cable, our Samsung series 6 51" LCD tv requires having the source output on HDMI3. Is there a way to change the " TV " button on the remote to...
We had this same problem on our Samsung 5 series. What we ended up doing was leaving the PVR plugged into HDMI 3 and renamed HDMI 3 to PVR. If you go to your source list and hit the Tools button (i believe its Tools) you should get the option to rename or give a nickname to a particular source.
Jan 10, 2011 | Televison & Video
When I turn the tv on, it comes on in DVD mode and won't change over to the tv mode.
You have two ways to change it to TV Mode.
1 - remote control (source button) -cycle through the options.
2 - side of the unit (source button) -cycle through the options.
If the remote doesn't work, try using the button on the TV to change the source mode.
If this doesn't work, you have a problem with the TV.
Another option is to check your inputs. If you have the input for the DVD in the wrong place, that may also be causing you the inability to change from DVD mode.
Apr 28, 2010 | Akai LCT2721AD 27 in. LCD Television
Finding the AUX button
With the stereo on, hold your Source button to turn the stereo off.
The hold the function button, a menu will appear, press function repeatedly until you see the Aux setting, and you will have an option to enable it with the navigation keys.
Once done press your source button to turn the stereo back on, and then go through the varioud sources and ye shall now find Aux as an additional source ;o)
Dec 05, 2007 | Pioneer DEH-P8200r CD Player
Samsung TV Remote Control Logo
403 people viewed this question
Henry  Thomas
Henry Thomas
