Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Have f1 fault cant get bottom draw out to check for moister build up
  • Fisher and P... Master
  • 3,247 Answers
The reason that you are getting F1 fault might be the dishwasher drawer is flooding. The drawer not opening is perhaps due to either the keylock being activated or the controller has gone into some unkown state.
Try turning the mains water inlet water tap off and also switch off the power. Turn everthing back on and then check if you can open the drawer. If you have water inside the drawer you may need to empty it manually with a small container. If it floods again, then the solenoid that turns of the power or the water level sensor might be faulty.
Posted on Nov 12, 2009
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Check out www.ApplianceRepairLesson.com. I hope this is what you needed, and it works for you. Good luck!
Nov 07, 2014 | Dishwashers
F1 fault wil not turn off
The alarm will continue until you unplug the machine. There is water in the base, this model has a very good flood protection base. Each tub puper & lowre has a lid which closes down thanks to two lid motors which pull it down, if yo place an object that is higher than the rim of the tub it can cause water to flow over the edge & creat a flood fault (F1). The other way is if you use the wrong detergent (liquid) or full sized tablets, it can cause sudsing that forces it's way into the base, agian F1. Solution remove the bottom draw, I posted that earlier, & dry out water with a cloth then blow dry all moisture away, good luck.
Dec 04, 2011 | Fisher and Paykel DD605HSS 23 in. Built-in...
I have a 10 year old dishdraw (Model No DD601v2). It is displaying a fault message "F1" on the top draw display and will not start. What fault is this indicating?
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dryer not heating up when it's on. All the buttons seem to be working on the panel and it still runs.
First clean the entire venting system to the exhuast duct work. A moister sensor detects any build up of lint and keeps the heat (burner) in check. If at is all cleaned and still no heat listen for the spark ignitor to click upon starting. If not heard the ignitor is at fault. If it di=oes click the moister sensor is at fault then
Jun 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Clothes have to be dried several times before getting dry
The first thing to do is to remove the ryers exhaust venting tubes and clean them out thoroughly. Any lint build up will cause the moister sensor to keep the heat in check. It is a saftey device to prevent home fires from clothes dryers. Just on small clog will do this. If cleaned and still no heat listen for a clicking noise upon starting. If no click is heard the Spark ignitor is at fault. If it is clicking the moister sensor is at fault
Jun 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a matag neptune gas dryer and it does not heat up but turns I am not sure the year of it . It is digital
The heat will not turn on for a few reasons or possibly just one
First remove the exhaust duct work and clean thoroughly
Any lint build up will cause the moister sensor to put the burner in check
Also after you had cleaned it and still no heat, listen for the spark ignitor to click when first turned on. That ignites the burner. If no clicking is heard the spark ignitor is at fault. If it does work the moister sensor is at fault instead
Jun 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dry will not heat
Do this first
Remove all exhaust vent tubing and clean it out thoroughly.
Any lint build up will prevent the burner to operate
A moister sensor stops the burner when it senses lint build up
Reattach the vents now and proceed to the next steps below
If thoroughly cleaned & no build up is present start the dryer and listen for the spark ignitor to click. If it does not click the ignitor is bad. If it does click and no heat appears to come through the dryers drum within 30 seconds the moister sensor is at fault
May 17, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
HI I HAVE A F2 CODE ON MY TOP DRAW OF MY DELONGHI DOUBLE DRAW
You will need.to remove the draws and dry the under tray as it has a flood.warning sensor to detect water, this is due to lime.building up.around the tub top.seal and will.need.cleaning off as it causes leaks to run down into the tray
May 12, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
RE: Fischer paykal F1 code
F1 fault means the flood switch on the base of the dishwashers has been activated.
nine times out of ten its the lid motors.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Aug 04, 2008 | Fisher DD603FCSS Dishwasher
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
136 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
