Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
KP-57WV600 The tv started showing a reddish shadow. When I cover the red bulb, the picture looks good, except for the red colors that don?t show. I am wondering if I can fix it by replacing the bulb?
  • lcloya1 Feb 05, 2010
    Yes it does, it looks like 3D
    Thanks
  • 10,594 Answers
Do Not do any thing with Red Bulb (picture tube).
Let me ask couple of questions about picture problem.
1- Does TV show red picture separately like 3D picture effect or do you see double picture in screen?
2- Does TV give red shadow on high bright scene, specially on white objects in picture?
Let me know about above symptoms to suggest solution.
Thanks.
Posted on Nov 12, 2009
  • Shahid Electronics
    Shahid Electronics Feb 05, 2010
    OK, symptom shows it is convergence out chips failure problem that causing double picture.
    Replace convergence out chips on D Board. If you are handy with electronics stuff repair and can replace parts in circuit board then let me know to provide you required part info and where these can be order.
    No Problem.
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Tv shows images in red, blue and yellow colors only
Tv have a problems known as a convergence picture problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead.This tv convergence board must be repairs,u must require to replaced components parts like 2 STK convergence ICS and some or all of it resistors too.To fixed the the tv convergence board to solved the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Jun 29, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
PICTURE HAS GREEN AND VIOLET OUTLINING ON FIGURES AND DOUBLE ON WORDING
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 04, 2011 | Sony KP-57WV600 57" Rear Projection...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
TV showing Red shadows when viewing the picture
Open the TV set and at the end of the CRT, there is a Circuit board (Video baord) where color adjustments are manually done there. OK, normally there are cracks or cold solders on the terminal of the components which can be the cause. You'll need a technician to do the re-soldering of the terminals. cheers.
Oct 31, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Red color halo/shadowing
can you post a pic of your screen to show the shadowing, as red usually isnt affected with coolant contamination it may be a convergence issue. A pic would help me be better able to help diagnose the problem.
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
