Question about Kenmore 23822 Top Load Washer
My washing machine will not spin sometimes and will not drain
  • mydarlingana Nov 12, 2009
    11020922990 ModelNo: Sears Kenmore My machine will not spin until I spin it manually then it spins slowly picking up more speed but it is not pulling the water from the clothes I have to reset the spin cycle several times to get it up to top speed for it to pull the water out of the clothes of course it is making my dryer work harder to dry the clothes
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines. This initially points to a lid switch problem but it would be best to have the exact model number in order to provide a better solution.
  • 20 Answers
Lid switch is bad
Posted on Nov 12, 2009
Washing machine washes then will not spin HELP HELP dirty clothes
When you set "the timer to drain and spin only". After "drain" program finished - not pump or motor sound or all sound stoped, the machine is freeze?
The meaning is sometimes, the sensor of water level doesn't working properly. The "drain" program is keeping running.
May 27, 2017 | Washing Machines
My Kenmore washer will sometimes drain the water but the clothes are still very wet as though it did not spin. There seems to be no pattern to when it will do it. When it is spun again, it will work. ...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 28, 2011 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 series washing machine will not always drain out on the spin cycle and sometimes when it does there is dirt in the tub under the clothes. why?
heatman101
Apr 02, 2011 | Washing Machines
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
heatman101
Mar 22, 2011 | Washing Machines
Not spinning water from machine completely..... have to remove some of the clothes and restart spin ......also has a squeak sometime. Thanks for your help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Oct 05, 2010 | Frigidaire GLTF2070DS Front Load Washer
Washer will not operate error code LD We have unplugged washer moved clothes around and tried to just spin water out. All lights come on and sometimes the lid will lock and sometimes it want but washer...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Washing machine wont spin and only drains when it wants to
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Jun 19, 2009 | Washing Machines
WASHING MACHINE WON'T DRAIN ALL THE WATER
Check the drain hose for a kink, or inspect it for plugging with lint. Hope this helps!
Feb 16, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 23822 Top Load Washer Logo
527 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
