Question about Cozy Enclosed Front Console Heater 35,000 btuh Propane
I installed a new Cozy heater and it smokes while running.What's wrong?
  • Cozy Master
  • 43,501 Answers
If it is brand new they will often make some smoke on start up. Run for 10-15 min. and it should clear up.
Posted on Nov 12, 2009
Cozy wall heater
Check flue pipe,old flue pipe may have soot,also check vent flashing may be restricted
Jun 25, 2014 | Cozy (W352E) Heater
I have a cozy dual furnace that makes a lot of noise when running it makes a snapping noise when heating very loud . The flame some times sounds like it is sucking to much air then it clears
measure from floor to top of grill should have 68 3/8 of an inch if not the header plate(separate part from unit) is installed wrong which can cause noise.
Apr 21, 2014 | Cozy (W352E) Heater
Cozy heater #cdv 155 anticipator setting
Has to be a millivolt stat, if you have a 24v or 30 v on stat it is wrong, no anticipator setting on dc systems.
Feb 03, 2014 | Cozy Heating & Cooling
I have had problems with my Cozy gas wall furnace since it was new (its about 6 yrs old now) I won't stay on. It seems that every year I have to call out service people to get it to work. It always...
if the switch at the top of unit is tripping there is something wrong with the vent , the switch is set at 350 degrees it detects back draft do to a improper vent or blockage of vent, if the installer use the old vent system that is more than likley the problem, have the installer call Cozy tech line at 502-589-5380 so they can go over how the unit is installed.
Dec 07, 2010 | Cozy (W352E) Heater
New cozy wall heater makes alot of noise from heatexchanger poping and banging noises
if this is a w series unit measure from the top of grill to the floor, should have 68 3/8 on an inch if not the header plate which is installed in the wall was put in wrong have the installer correct this and the noise will go away. Cozy tech line is 502-589-5380 have the installer call so they can go over the install of the unit.
Dec 06, 2010 | Cozy (W352E) Heater
My heater will not stay running. Can get it to turn on and run for a few minutes but then goes out and can not be started again Thermocoupler is 5 years old
change the thermocouple. a universal one should fit. however does this fire have a oxygen depletion device on it (check instructions) at the very least a smoke match test should be carried out. Would definately advise getting it checked out by a proffessional service engineer
Nov 04, 2010 | Cozy (VCR502A-BM) Heater
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Heating & Cooling Logo
46 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
