Question about Crosley CDE6000 Electric Dryer
Make a lot noise like a bearing going out - Crosley CDE6000 Electric Dryer
  • Crosley Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 12, 2009
What is causing the whining noise in my 2005 ford five hundred all wheel drive
Whining or humming noise come lots of time from wheel bearing when you go straith and move the stering from side to side the noise is less noisy if so its 1 or 2 wheel bearing that need to de replace
Mar 15, 2015 | 2005 Ford Five Hundred
2009 impala. Noise in right front when turning right just briefly. The skid an abs lights flash but go back off.
You need to check your brakes right away, it could save you a crash and a lot of money.
Feb 03, 2015 | 2009 Chevrolet Impala
Noise in the primary case might be rear primary drive bearing. What are symtoms of bad bearing?
Well, they usually make a lot of noise before they lock up or come apart. If it's the bearing in the primary that the mainshaft comes through, with the bike running and in gear, hold the clutch in and the noise should go away. This is because the mainshaft is not turning and therefore the bearing is not turning. They don't make a noise when they don't turn. If the noise is still there, it could be the large bearing between the inner and outer clutch hubs. In this case, when you let out on the clutch, the noise should stop because the clutch locks up and the bearing doesn't turn. If neither of these apply, your noise may be somewhere else. Still if I suspected these bearings, I'd go into the primary and check them out. If it is a bad bearing, you can feel the roughness in it when you turn it with you hands.
Good Luck
Steve
Jun 20, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
I have a 2002 Sebring with 150k on it. Last year I put new radials all around. I am getting a lot of road noise/droning sound. I don't get any shaking or clanging pulling when braking. My car ride straight...
yes the bearing go often when you go straith you hear a humming noise when you change lane sometime the noise get louder or quieter that your bearing let me no and thank you for using fixya
Mar 01, 2011 | 2002 Chrysler Sebring
I MY 1998 4 RUNNER HAS A HUMMING NOISE .
If the humming noise is at idle and the noise is coming from the middle of the engine , there is a lot of probabilities that the idler pulley for the timing belt is going bed.
If the noise is coming when the vehicle is moving ,the problem is a wheel bearing, the way to test for this bearings is a s follow, while driving in a empty street at the speed where the noise is present, go to the left the noise increases replace left bearing, go to the right the noise increase replace right wheel bearing.
Jan 16, 2011 | 1998 Toyota 4Runner
Noisy front end. any little bumb sends rough sound. the car rides great. I cannot stand the noise. I am about to change the struts, the sound is more a suspention point that is set up.
Before you change the struts check the stabilizer linkages and bushings. They will make a lot more noise a lot easier than a strut will. Also check the torque on the strut bearing bolts that go up through the strut tower. While the car is sitting, Push down hard on the front end and listen for where the noise is coming from. Other possible sources of the noise are the lower ball joints or the strut bearing. If you are changing the struts, change the strut bearings as well. You don't want to have to unbolt everything again if they go bad in ten thousand more miles. Good luck.
Apr 20, 2010 | 2006 Ford Five Hundred
Sounds like a bearing going bad where do i look first
a rod bearing makes noise when you are just barely pulling .. it likely will quiet down as you accelerate and decellerate .. you can rev the engine up a bit then let up on the gas just enough to keep that rpm ..a rod bearing will rattle a lot then ... if a thud like noise happens when you are accelerating . then it could be a main bearing .. if the noise is there all the time and sounds like a rattle then its more likely a valve problem .. old oil can cause the lifters to stick and rattle continuously .. if the noise you hear is a squeal then you could have a bad bearing in the idler pully (for fan belt) or alternator .. if thats the case you can put a drop of oil on the bearings one at a time until the squeal goes away .. that will identify which part is going bad .. there are other less likely bearings that can go bad .. like the cam, distributer, air compressor and water pump .. each have their own type noise ..
Oct 23, 2009 | 2003 Chevrolet Monte Carlo
Strange noise
Well sounds like belt ore fly wheel the bearing go out on them
Bearing in the fly wheels go bad and make hell lot racket i had guy with honda this happend and i told him and that what it was.
Jul 20, 2009 | 2005 Ford Focus
Crosley CDE6000 Electric Dryer Logo
90 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
