Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker won't let in water.so it won't make ice.
  • 20 Answers
Clogged tube to the ice maker from the valve...or bad valve. As long as you see the ice maker turning and no water comes in, it is one of the 2.
take the head off the ice maker and put a jumper wire between the letter
l and the letter v...stick the wire in the 2 holes...make sure the part you are holding is insulated. Water should go right into the icemaker....if not you have a bad valve or clogged tube
Posted on Nov 12, 2009
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Tfx20r ice maker won't fill
Try this fill the ice maker with tap water so we can decide if it is the ice maker or the water control valve. After the water freezes if the ice dumps and the ice maker does not refill with water then you will need to replace the=> WR57X10033 Water Control Valve If the ice maker does nothing after being filled with tap water and the water freezes then this would point to the=> WR30X10093 Ice Maker Assembly If you have questions I will be here to answer them for you, Thanks, Sea Breeze
Jul 06, 2012 | Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Water supply for ice maker won't turn off
Its either the water valve thats not closing, or the ice maker not telling the water valve to shut off.
Turn off the ice maker, and see if water still pours out, or even better, unplug the refrigerator and if the water still pours out of the ice maker, then the water valve is bad and you should have it replaced.
Jun 20, 2011 | Kitchen Ranges
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
