Question about Dell Dimension XPS 400 PC Desktop
Dell Dimension XPS GEN 5 IDE Philips CD DVD drive failed. So I tried a Liteon SATA CD DVD drive, but that wouldn't work. So I tried a Samsung IDE CD DVD drive and that won't work. I'm guessing mobo driver issue?
    Sergeant:
  • 267 Answers
First try installing one and go to your bios and set your bios to default . save you changes and exit.
also in my computer look and see if it appears there
if so you know its being reconized.
rite click it go to properties and then hardware
select the drive if you have gotten this far meaning you saw the drive. . go to properties and see if it says its working properly. it could also be that none of the drives your trying to install are compatible.
Posted on Nov 12, 2009
My dell 170L with IDE h/drive & cd rom wont recognise a sata dvd rom ( connected to sata port & power)
Check that jumper settings are done correctly, also check how devices are shown in BIOS.
Sep 14, 2012 | Dell Dimension XPS 400 PC Desktop
Dell Dimension XPS GEN 5 Bootmgr is missing
wrong jumper settings on hard drives
Aug 04, 2017 | Dell XPS M1330 Notebook
What cable do i need to hook up samsung ts-h663b 22x dvdrw sata to dell dimension 2400
You are going to need more than a cable to connect a SATA drive to the Dell Dimension 2400's motherboard. The motherboard only supports IDE devices.
Assuming the original power supply, you need either a SATA controller PCI card (and an available slot) and a 4 pin device to 15 pin SATA power converter (like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812270313&cm_re=ide_to_sata_adapter-_-12-270-313-_-Product)) or an IDE to SATA data connector (like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16812119257&cm_re=ide_to_sata_adapter-_-12-119-257-_-Product )
The IDE to SATA data connectors come in a couple of types. Some plug into the 40 pin connector on the motherboard (and you will need a power adapter); others plug into the SATA drive and usually accept the 4 pin device power connector.
I hope this helps.
(If you have upgraded the power supply to one with SATA power connectors, then you do not need the power adapter.)
Feb 06, 2011 | Samsung Computers & Internet
My cd/dvd burner won't work. i put in a cd and a green light blinks a few times and nothing happens. My Dell is a dimension E520. thanks!
In MY Computer, check to see if the DVD drive icon is there.
Try a different DVD or CD brand
Check the sata or IDE cable connection to the rear of the drive and also the security of the power rail
Dec 28, 2010 | Dell (M6790) DVD RW Burner
Dell XPS/Dimension and BLUE SCREEN OF Death!!
have you tried changing your hard disk drive? if not, try to change your hard disk drive. then start installing new windows.
Mar 24, 2010 | Dell Dimension XPS Gen 4 PC Desktop
I need to buy an internal CD burner for my Dell Dimension 3100. The original won't burn a CD properly. Which replacement (internal) should I buy?
This is a matter of opinion but a really good brand and cost effective will be a LiteOn brand one.
For your model, you support Sata. The drive may already be sata or it may be ide. here are links to both types.
IDE
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106281
SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
you may also want to look at LG models as well. they are very good and usually what many companies use for their oems
LG SATA version
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136167
Feb 17, 2010 | Dell Dimension 3100 PC Desktop
Need to replace the CD/DVD combo. It will not
Any SATA DVD combo should work they are all industry standards.
Jan 26, 2010 | Dell Dimension XPS PC Desktop
Gear Head Lightscribe 24x DVD+/-R Triple Format SATA
Your original CDROM drive is likely an IDE interface (large rectangular connector), where as the new one is a SATA interface (small narrow connector). If your original is an IDE, the simplest solution is to return the SATA and purchase an IDE DVD.
Oct 26, 2009 | Gear Head 8XDVDEXT DVD External Slim...
Computer
The Drive you purchased is a SATA interface, the system you have uses Parallal ATA IDE interface.
You need to get a Drive with an IDE interface for that system.
Jul 30, 2008 | Computers & Internet
Dell Dimension XPS 400 PC Desktop Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
