Question about Admiral AW22 Top Load Washer
Loose belt how to adjust - Admiral AW22 Top Load Washer
  • 155 Answers
Turn off power lean machine over loosen motor bolts enough to allow motor to slide adjust tension while re tightening bolts hope this helps
Posted on Nov 12, 2009
My treadmill when I step on stop. The motor is going but no the bell
Your belt is either worn or out of adjustment and too loose. Some treadmills actually have 2 belts depending on the drive system. Some have a small belt that goes from the actual motor to a pulley that is attached to walking belt drive system. If the big walking belt is tight you may have that system and the small belt needs tightened. Other systems have the motor connected directly to the big walking belt and in this system my guess would be the big walking belt is loose. Most have adjustment screws at the back end of the treadmill frame along side the belt to make it tighter. Adjust both sides the same so it tracks straight.
Apr 02, 2015 | Exercise & Fitness
How check motor burned up
Loosen the belt and try to see if it will run. If it runs then you need to redo your adjustment. The belt can't be too tight or too loose and it must be perfectly aligned. The best way to do this is remove the top thread. While pushing the foot speed control adjust the belt tighter, more loose and side to side until the motor is at it's maximum speed. Tighten the motor and retry. While doing this be careful!
Feb 16, 2015 | Sewing Machines
Harley drive belt wont stay tight after adjustment
Hi Djpiccir, sounds like your axle nut is bottoming on the axle shoulder due to wrong washers or placement of washers. For more information on your problem please visit the website below and good luck. http://www.stcharlesharleydavidson.com/OEMpartfinder.htm#/Harley-Davidson%C2%AE/FLHTCU_FC_ELECTRA_GLIDE_ULTRA_CLASSIC_(EFI)_(2007)/REAR_WHEEL/99456-07B%5CFC/99456-07B%5CREAR%7C~WHEEL%5CFC
Apr 21, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
Replacement belt loose
There is an adjuster for both drive belts which may be there
Feb 29, 2012 | 2001 Subaru Outback
Steering wheel shakes when the Aircon unit is on but if the Aircon is off it seems okey. pls advised.
First, check the level of your power steering fluid and top up the level if low. Then adjust your serpentine belts. A loose belt may be causing the the steering wheel. To adjust your alternator belt . First , take off the negative battery cable so you do not blow an expensive fuse on the positive battery cable clamp. Facing the back of the car, reach UNDER the alternator and loosen the bolt on the bottom right side, now loosen the bolt on the adjuster block on top, you can now turn the adjuster bolt and move the alternator to change or adjust the belt.
To take off or adjust the steering pump belt on the front of the motor, you need to loosen the nut on the back side of the adjuster pulley (right side ,belt is on the left) . With the adjuster pulley loose , you can use the adjuster bolt to move the pulley forward and backward to adjust the steering pump belt tension
Jul 12, 2011 | 1994 Mitsubishi Galant
Have a 2002 RX300 that needs the Alt. belt replaced. Bolts a real pain to get to. Have them (3) loose. Do any need to come out or just loose? Thank you
You are only supposed to losen then. Here are some good instruction with layout that might be of help:
REMOVAL:
  1. Loosen the pivot bolt and adjusting lock bolt. Torque: Pivot bolt: 38 foot pounds. Adjusting lock bolt: 13 foot pounds.
  2. Loosen the drive belt tension by adjusting bolt and remove the drive belt
INSTALLATION:
  1. Installation is in the reverse order of removal.
To remove the P/S belt, remove the right fender apron. Then loosen the pivot and adjusting bolts, swing the P/S pump towards the engine and remove the P/S belt.
Jun 06, 2011 | 2000 Lexus RX 300
I cannot adjust the alternator belt for my ford transit 2002
get new belt maybe strecth.dont this have tensioner's. is belt loose coming off or what the reason to adjust.
Dec 11, 2010 | Ford Transit Connect Cars & Trucks
How to adjust the seepentine belt on the 1988
There is no adjustment for the serpentine belt.It has a belt tensioner and is self adjusting.If the tension is loose then you have to replace the belt tensioner.Hope this helps.Good luck.
Jul 21, 2010 | 1988 Chevrolet Celebrity
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
Change drive belt //
loosen the the two bolts (show on the figure above) first
loosen also the bolt used for adjusting tension.
remove the old worn-out belt.
place the new belt (you may need to loosen further the tension adjusting bolt)
when belt is properly place, tighten it enough the tension adjusting bolt,
(not too tight, but not too loose) press the belt to ensure its not too loose!
When belt tightness is enough, tighten the the other lower one of the two bolt then the lastly tighten the pivot bolt.
gookluck!!!!
Oct 31, 2008 | 2002 Nissan Maxima
Admiral AW22 Top Load Washer Logo
118 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
