Question about Car Audio & Video
The radio in my 1989 GMC is really erradict and comes and goes.Is this a common problem with these?
  • blhensley Nov 12, 2009
    I think you are right!
  • 1,068 Answers
Yes after time i see this alot and is time to replace it with and aftermarket one because you could find yourself with the same issue you have now if you go with a used oem one. hope this helps and good luck.
Posted on Nov 12, 2009
  • michael schultz
    michael schultz Nov 12, 2009
    wel good luck and let me know if you have more questions.
  • 11,896 Answers
It is a common GM radio problem. Especially in their trucks. I would recommend going to junkyard and get similar used or just get a cd player and wiring adapter and install that instead. They are cheap.
Walmart, ebay, amazon.com
1989 GMC Sierra taking to much fuel floods out
Bad temp sensor ? Just a shot in the dark without being there to check it myself but a common problem.
Mar 09, 2015 | 1989 GMC Sierra
1989 gmc s15 2.5 - check engine light comes on - the code states a running lean condition. It comes on and goes off. When it goes off, I'm assuming it's going into closed loop and runs poorly and acts...
Hook up a fuel pressure gauge to the schraeder valve, and then operate the vehicle. I'll bet you will see a corolation between the performance and the fuel pressure. This would indicate a failing fuel pump.
Feb 23, 2011 | 1989 GMC S-15 Jimmy
My 1989 gmc sirrea 350 set the timing replaced the tps map and idle control valve idles great just hesitates on take off what could cause this
At first thought mine would be a dirty throttle body. This is the area just below the throttle plate. A good cleaning could help out. Do this after the enging is warmed up then shut off. Dissconnect the battery, yea I know you will lose radio stations, but as a saftey issue. Take a rag with carb cleaner , open the throttle and wipe it off with the rag. Really works on Chrysler products.
Michael A.
Jan 18, 2011 | 1989 Chevrolet Celebrity
1989 GMC Suburban speedomeeter
would imagine the internal speedo gears are skipping when cold. They are located in the transmission where the cable goes into. It is easily removed to inspect
Mar 27, 2010 | 1989 GMC Suburban
Where does the blue/white remote wire hook to.
Hi, I'm not sure I understand your question. It sounds to me like you haev a 1989 GMC truck, and you've installed a JVC CD player in it. The CD player has a blue and white wire coming out of the back, and you would like to know where it goes and what it does. Is that right? If so, then the blue/white wire labeled "Remote" coming out of your CD player is intended to turn on an external amplifier or some other "remote device". If your truck has a power antenna installed, this would be the wire that tells your power antenna to extend and retract. Many stereos have two of these wires - one for the power antenna and one for an amplifier. If you don't have an amplifier or power antenna, you don't need to do anything with this wire, just leave it alone and make sure it doesn't touch any bare metal behind the radio. Hope this helps.
May 16, 2009 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
