Question about GE 32GT740 32" TV
Won't turn on. makes whiney noise. fuse ok - GE 32GT740 32" TV
  • 541 Answers
The set has a shorted horizontal output transistor and possibly a bad high voltage transformer. The transistor can be checked with a DVM but the transformer has to have its impedance checked with a "ringer". Also solder all stages in the drive circuit of the horizontal transistor. The power supply is making the noises because of the short on the secondary side. Thanks for using fixya.
Posted on Nov 13, 2009
Engine stopped while driving will not start again, starter sounds funny
open ur driverside door and check ur fuses reel good. even check if the fuses have a grayish color coat on the prongs. these cars and the grand am had a problem with the windshield leekinf right by the fuse box and causing fuses not to work right even if they look good
Oct 06, 2012 | 2002 Chevrolet Cavalier
No elecectrical won't start
hi lynn. the first thing i would check is battery and battery conection, after that, fuses . J would have to have more information about your dodge to determine what is wrong with it.( does it make any noises when u start up the engine? if you know the battery is ok but wont start up, u should listen if fuel pump is working after u turn key on in ignition. If fuel pump doesn't make any noises thats praboblay what is wrong solution : new pump
Sep 21, 2012 | 2003 Dodge Caravan
2007 saturn sky
The common cause would be the power steering pump, it is rather low on fluid due to a leak in the system or it is defective.
Sep 10, 2012 | Cars & Trucks
Whiney noise
Diagnosing a noise like this is nearly impossible over the internet, have a local shop look into this noise.
Jul 19, 2012 | Cars & Trucks
RA n out of gas won't start
remove gas cap put ear close to filler tube and have someone turn on key listen for pump to turn on it will be a buzzing noise if you hear this then try replacing the fuel filter if there is no noise check the fuel pump fuse if the fuse is ok then replace the fuel pump
Mar 26, 2012 | 1999 Chevrolet Silverado 1500
All of a sudden my car won't start. The battery is good, lights work It's not clicking like it's trying to start. The engine is okay, the starter usually makes that horrible waahh whiney sound...
it can actually be your starter. many times a bad starter just wont turn at all. it can be that, a short, or the only other thing i can think of would be a blown starter fuse. you can check your fuse box in the engine compartment, it should be like a 50 to 80 amp fuse thats in a little clear box in the fuse section of your fuse compartment. hope this helps. and if fuse is good, you can try poking the starter with a stick and try to start. if it does something after poking it, then its the starter
May 13, 2011 | 1994 Toyota Corolla
Van makes noise when i accelerate
if its a whiney noise probably gearbox going or if its a clunky kind of sound probably steering rod ends or steering linkage...just had both done on my own van
Jan 10, 2011 | 2001 Chrysler Town & Country
Rear diff noise
We have to be sure where the noise is coming from, a advise you or ask someone to do the following tests:
  1. jack your both your rear tires and make sure its stable. turn your tires either manually or by shifting gear into reverse and try listening to any humming or whiny sound or vibration not only from your rear differentials but also your transmisssion and independent transfer case.
  2. Be sure it secured and will not move and will not squish you under.
  3. also check on your rear propellers, differentials for excessive play
  4. If you determined where it is coming from, check on your gear oils.
My own assesment from what you have just told us, is I would also check on your clutch system, because whiney noise only exist when you are backing up the car. I hope you would pin point which part is causing the whiney noise to save you all the headache of having it repaired.
Comment after you determine where it is coming from.
Thanks for dropping by fixya
Nov 24, 2008 | 1994 Suzuki Samurai
Whiney noise as i drive Volvo V70, even when i turn the car off
this sounds like the bearing in the thermostatic cooling fan has worn possibly lift bonnet with car started keep hands out and look for a fan on the front of the radiator the are usually black plastic and are easily replaced and become noisy when worn hope this is helpful glenn....
Nov 23, 2008 | 2002 Volvo V70
GE 32GT740 32" TV Logo
191 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
