Question about Dryers
Stink Smell from Electric Clothes Dryer/Fuse Box
I have a 5-year old electric clothes dryer. It worked fine until last month. After the dryer running 4 or 5 minutes, a stink smell comes out into the laundry. If the loading is an extremely light (say 3 T-shirts), there is no smell. However, the problem happens even with a load of 1 jean. Tried to solve the problem, I checked and cleaned the inner cabinet, the lint screen, the air-passage after the lint screen to the connecting ring to the the vent (including the fan), the vent, and the exhaust hood, but it doesn't work. There is no new installation in the laundry (nor not newly painted), except a replacement of a circuit break in the fuse box.
When (and only when) the dryer is running, there is a very little "tick" sound comes out from the fuse box at a interval of 5 to 10 seconds. Since the fuse is above the dryer, I cannot tell whether the fuse box is the source of the smell.
Best Regards,
  • Selma_china Jan 09, 2008
    Thanks for your advice. It seems the smell does no come from the replaced circuit-breaker. In fact the replaced circuit-breaker is for the receptacles in my kitchen not to support the dryer.
    Problem Solver:
  • 13 Answers
This should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Posted on Jan 07, 2008
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Burnt smell when dryer running
it could be what your washing your clothes with.
Feb 28, 2009 | Whirlpool LEQ9858P Electric Dryer
Hotpont/Zanussi Electric dryer TC7102W no timed heat
it seems thatyour getting no heat on the permanent press and gentle cycles correct? if we know the heater is working that takes care of a number of possible causes turn the power off and remove the rear panel of the dryer. you will see a couple of thermo disks mounted on the heater probably will find tons of lint on these thermostats and what happens is you turn your dryer on low heat or automatic cycle where the dryer will run until it senses the clothes have no more humidity inside the drum every time the thermostat shuts off the heater the dial moves a little closer to the off position. if there is a build up of lint around these sensers the dryer will heat up until the sensers turn the heat off. what happens now is the thermostats are nice and warm as the lint buildup iacts like an insulator preventing the thermostat from calling for more heat so it will take forever to dry a load of clothes. brush the lint off the thermostats and while you are at it vacuum the back of the dryer there should be a lot of lint there
Jan 23, 2009 | Zanussi TC7102W Electric Dryer
Dryer stops running and displays E1
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Dryers Logo
570 people viewed this question
Top Dryers Experts
