Question about Hotpoint RVM1635 Microwave Oven
The exhaust fan is not 'sucking' air from the bottom of the microwave, it is pulling in air from the upper right of the unit. Why?
  • 1 more comment
  • mmplessner Nov 12, 2009
    woodsman,
    thanks for the response. the damper is not stuck and i have removed the filter. there are 2 fans in my microwave, the larger black one expels air out the vent and this is working very well. there is a smaller grey fan that is sucking air from the top of the unit not from underneath where the filter is. i have a build-up of grease in this area but my filter is very clean. what is going on?
    woodsman,
  • Jim Thurston May 11, 2010
    If this unit is vented out, check to see if the damper is stuck on the vent. If not vented check to see if filters need to be cleaned. Most filters will clean in the dishwasher.
  • 670 Answers
Not to be redundant , but there are two dampers on a microwave that is vented out. One attached to the unit and one on the exterior of the building. Have you checked both? I am from the mechanical side of appliances, not the technical side but i believe the large fan vents steam and odors from the cooktop and the small fan cools and vents the micro conpertment. I'll check with others and get back with you.
Posted on Nov 12, 2009
  • Jim Thurston Nov 12, 2009
    Been thinking of your microhood today. Is this a new install or a new home where someone else has installed the unit? The exhaust fan is tri-directional, either to the outside through the back or top or back into the room through a filter. The fan has to be installed in the hood pointing in the desire exhaust direction . It is possible that the fan is turned in the wrong direction. It will still run but has nowhere to exhaust if this the case. If it is the unit has to come back down to change the blower direction. Let me know, Jim.
No suction on my microwave
Over-the-range microwaves have lights and fans in them mostly for show. They protect the microwave from heat rising from the stove and provide a light to illuminate the stove top. The fan assembly is far too small to generate any real pull or draft and if it did, it would only blow it back in your face since these models do not exhaust to the outside; they only exhaust out the front of the microwave. A few models have a "filter screen" that is supposedly there to catch grease and contaminates but really it only serves to further weaken the draft as it provides a resistance to air flow.
Oct 14, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Kenmore Elite Microwave Hood Combination fan blows air out of the top but is not sucking in the heat from anything on the stove...for example boiling water.
does th fan exhaust to the outside --filter clean --directional duct to out side --also small unit so will not suck air like a standard stand alone exhaust fan which are over 3 to 4x the size
Jul 31, 2016 | Kenmore Microwave Ovens
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
Overhead maytag microwave fan works but no suction why
There is NO Suction on a Microwave, what you mean is Air Movement. If the Fan is turning, then there is Air Flow
Sep 22, 2014 | Microwave Ovens
Can a Kenmore Microwave oven Model 401.8504*, 85143 be put on a counter top and used?
Most over-the-range (OTR) microwave ovens have the exhaust fan funning at low speed when the microwave oven is working. This is to keep the magnetron and electronics cool. And it sucks air in from the bottom, so if you just place this microwave flat on the countertop, it won't be able to suck air in, and it could overheat if you use it for more than just a few minutes. But if you can put it on some boards or some sort of grill so air can get to the bottom, then you should be okay to use it as a counter-top model.
Jul 02, 2014 | Kenmore Microwave Ovens
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
Exhaust fan
The fan pulls from the range top and either out those vents on top unless there is a vent in your upper cupboard. Then it is vented outside. Hope this helps.
Jan 07, 2008 | Maytag MMV1153A Microwave Oven
Hotpoint RVM1635 Microwave Oven Logo
861 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Jerry Greenberg
Jerry Greenberg
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
