Question about Ariens Garden
Wont start! getting gas has spark (maybe little weak) have put in fresh fuel, new spark plug , has been getting harder to start the few times i have used it.
  • 486 Answers
Suggest you check compression, if it is less than 75 psi, you may have internal wear of rings
Posted on Nov 12, 2009
  • Faheem Qureshi Sep 29, 2013
    Roland how doe one check the compression. The Mower is only 2 years old.
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
2003 suzuki wont start ran good whenparked 2 mo ago checked plugs checked fuel
Make sure the battery is fully charged. Consider getting a jump from another vehicle and if that doesn't work buy a can of ether starting fluid from the local walmart or auto store. Make sure not to keep turning the motor over if the vehicle doesn't start - you will flood the motor with gas and can damage the pistons - excessive gas will wash off the oil and the starter will get very hot. If you have done that already consider removing the spark plugs and adding a few drop of engine oil to each cylinder and smell for gas - let it air out. When older cars sit unused problems can bubble up.
Nov 22, 2014 | Suzuki Motorcycles
Lawn mower wont start
I would put in a new spark plug, most non start problems are solved with fresh fuel and a new spark plug.
Sep 23, 2014 | Garden
Craftsman 675 series 190 cc lawn mower Wont start
Take air cleaner off. Shoot some spray carburetor cleaner in the carburetor and try to start Try this a few times to see if the engine will fire.. If it fires or starts then there is a fuel delivery problem. Could be a dirty fuel filter, bad (stale) gas, a dirty carburetor. If it does not start with the carb cleaner, check the spark plug. It may be fouled. Check for spark - take plug out of head. with the plug attached to plug wire, hold plug with a pair of insulated pliers, and touch outside of plug where the threads are to the engine, while some one pulls on the start cord. You should get a bluish spark. If you get a weak spark use a new plug and try again. There should be a bluish spark. Make sure you hold the plug against the engine making good contact. If no spark at all, could a bad magneto.
Getting back to the carburetor. If you think the gas in the tank is stale, drain it out and put fresh gas in the tank. Change the gas filter.
The arburator may be cleaned by pouring a 1/2 can of fuel system cleaner in the gas tank and spraying the spray cleaner down the carburetor throat.
Jun 03, 2014 | Garden
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
I have a weed eater trimmer that wont start. ben sitting for a couple years and i replaced the fuel lines andcleaned the carb. still nothing, what do i do?
Try cleaning the spark plug, make sure it sparks. Put some fresh gasoline in the tank, check start stop switch.
A easy way to check whether the problem is related to carb or not is:
remove the spark plug put some fresh gasoline in the cylinder, put the spark plug back
pull the starter a few times if it starts for a few seconds it means is related to carb.
Be carefully when handling gasoline.
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
I put new spark plugs in and new air filter unclogged my cadalac converter yet im still getting 200 miles on a full tank of gas what could be the problem?
distributor cap, distributor rotor, spark plug cables, these can cause a spark to be to weak, which would cause the car to use more gas than necessary. fuel filter would also cause lower fuel pressure which would cause the car to use the gas inefficiently. tire pressure, if under inflated will cause to the car to push a little bit harder which could cost you a couple of miles to the galon. these are the only things i can think of that affect gas. other than that it would be something would have to be replaced like your o2 sensors. hope this helps, goodluck
Jan 22, 2011 | 1992 Honda Accord
Bike sat for year,has spark,cranks over,but wont start,bad gas maybe?
yes buddy drain tank put fresh fuel in and kick it over a few turns to allow fresh fuel to flow into engine get back to me if still no start
Oct 04, 2009 | 1995 Yamaha XV 535 Virago DX
Wont start after 6 mos. I changed the spark plug, drained & added fresh gas, checked the fuel filter... Kicks over fine. Ran for 4 seconds, then it died. Always ran & started great before.
With a new plug and fresh gas it should start. Check to make sure there isn't a kill switch turned off or that the gas petcock from the tank to the carb is on.
How did you check the fuel filter? Disconnecting it from the fuel line that goes to the carb is the best way, making sure the gas is turned on under the tank. Bleed off a little gas into a can or something just to make sure the filter isn't plugged.
The last thing I'd do is take off the air filter and spray a little starting fluid in the carb. It may start and run several times if there is old gas in there somewhere. Remember the bowl on the carb is probably still full of old gas. After some fresh fuel reaches the plug it should start and continue to run.
(You might drain the bowl on the carb of ols gas before you go any further)
Sirwriter
May 22, 2009 | 2006 Honda Civic Hybrid
Tiller has sat in weater for a year. I changed the spark plug, and found there was water or gas in the oil (lots of it) i drained the oil and put in fresh but now it wont even start. what is my problem or...
You need a few things for a combustion engine to work. Firstly you are going to need to know a little about engines and how they work.
Fuel - try draining the tank and putting fresh fuel in it - fues does go stale. This will include fuel in the carburetor so that needs drained too. There was liquid, assuming water in the oil, perhaps it is in the fuel too.
Fire - do you get a spark to the spark plug? Pull the plug out and see if you get spark when trying to start - remember the earth of the spark plug needs to be touching the grounded metal such as the engine or frame. Perhaps the electricals have been water damaged.
Air - clean out the air filter and surrounds.
You have already drained the oil and replaced it - good start.
Maybe something has corroded since it has been in the weather for so long.
If it still does not want to start, try pulling out the plug & trying to start - is anything spitting out the spark plug hole? If so, what?
Once that is clean and clear and it still doesn't start but you have spark, try putting a bit of fuel carefully in the plug hole, say half a tablespoon.
How does that go?
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
100 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
