I PURCHASED NOMA 1500 WATT BASEBOARD HEATER AND
I PURCHASED NOMA 1500 WATT BASEBOARD HEATER AND CONNECTED THEM TO A NOMA THEROMOSTAT AND WHEN I TURNED THE POWER ON, THE THEROMOSTAT BLEW. CHECKED ALL THE WIRING AND NO GROUND FAULTS,BUT WHEN I CHECKED THE OHM RESISTANCE ON THE WHITE AND BLACK WIRE ON THE HEATER,IT SHOWED A RESISTANCE. THE WIRES ON THE OTHER END OF THE HEATER WERE NOT CONNECTED.I KNOW THERE SHOULD BE AN OPEN LINE ACCROSS THERE 2 WIRES AND WHEN YOU JOIN THE 2 WIRES AT THE OTHER END THEN CHECK WITH AN OHM METER,YOU SHOULD GET A READING.ANTBODY WITH A SUGGESION.UNABLE TO GET IN ANY CONTACT WITH NOMA.THANK YOU
I am haveing the same problem.........., the first 10 i installed no problems....... now the last one i am ..............did you have any luck
Posted on Nov 10, 2010
Noma ew7507ce manual
Timer is not identified.
Noma is a recognized brand name that is licensed to many different product manufacturers for a variety of different products including timers.
Check resources below:
1) Add a comment with clear description of timer, and/or post a photo on flickr and include link to photo
2) Open following link to see various Noma timers and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/images/NOMA-logo-1200.gif
3) If you have different product than a timer, for example an oil-burning radiator or electric baseboard heater then re-post question on fixya with clear description of product for possible research and information
Oct 03, 2011 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I installed a 1000 watt four foot long Farenheat F2544 baseboard heater in my outdoor workshop. But it's too small for the space. I calculated that I probably need 2000 watts to heat my space. But I do not...
I could find no electrical code or mechanical code that says you can do that, so I wouldn't do that.
But have you thought of or do you have the overhead space to install a hanging unit heater? They don't require much space(just make sure you install it per manufacturers specifications) and they come in much higher BTU ratings.
Nov 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Marley B2451 wall heater
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at http://www.qmarkmeh.com/
Doug
Jan 22, 2009 | Marley Electric Hydronic Baseboard Heater,...
I need a wiring diagram for a Fahrenheat electric baseboard heater. model # F2546NWC 1500 watt.
i dont have a diagram but i just did mine,,,its real easy to do...write back if you didnt solve your answer yet...
Dec 26, 2008 | Fahrenheat Electric Convector Baseboard...
Heater is not heating up.
First, is this a 120 VAC or 240 VAC heater? 120 VAC heater will usually have one Black & one White wire and 240 VAC heater will usually have two Black wires or one Black & one Red wire. If it is a 120 VAC heater then you need to supply the white wire at the heater with a neutral (white) wire from the breaker panel. If it is a 240 VAC heater then you need to verify that you have 240 VAC at the heater from Black lead to Red lead. If you are not sure about how to do this please have an experienced electrician look at it so you don't get electrocuted and/or burn up your new heater. Hope this helps!
Dec 09, 2008 | Fahrenheat Electric Convector Baseboard...
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
736 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
