Question about Acer Computers & Internet
I have the omnitech 8.5 digital picture frame and cannot download the Optipix Pro software that is supposed to be in the internal memory of the frame. Even without that, I cannot transfer my photos from my computer to the frame. The manual tells me I can drag the photos to the G drive, but when I try I get a message that says 'cannot copy IM00045. Cannot find the specified file. Make sure you specify the correct path and file name.' I use HP Image Zone to hold the photos on my computer. I know that they are Jpeg format so i don't understand what is wrong. Can you help? Jeannine
    Sergeant:
  • 163 Answers
Does your Digi Frame use Jpeg or PDF?
This could be the problem
Regards
Sir john Dana taylor
jdtay
Posted on Apr 23, 2017
softplanway
  • 53 Answers
SOURCE: philips photo frame
Heyo Nathan
here is the manual http://www.p4c.philips.com/files/7/7ff2fpa_00/7ff2fpa_00_dfu_aen.pdf
and here is the driver software on the Philips site
http://www.p4c.philips.com/na4/7/7ff2fpa_00/7ff2fpa_00_fus_aen.zip
good luck!
Wayne
Posted on Dec 28, 2007
  • 21 Answers
SOURCE: Error Messages.
Hi, did you try downloading your videos through the included software? It should work best using the included PowerCinema NE for Everio. If you are using windows Vista, then you need to download a patch. Here is the link: http://www2.cli.co.jp/products/ne/update_everioM7SD/pcm4e_update.htm
Make sure you have PowerCinema NE for Everio installed before applying the patch. After this, follow a few simple steps. Turn off your camcorder. Connect the USB cable to the computer then to the camcorder. Then, turn it on. The software should load automatically, and using that you should be able to download the files. You might need administrator rights for this.
Hope this helps,
Eric
Posted on Jan 29, 2008
SOURCE: Digital Photo Keychain
My copy of Photo Viewer came on the provided disk. Run set up to load it (if you do not have a disk go to the key ring manufacturers website). When you use Photo Viewer make sure that your key ring is attached to a USB port prior to starting the programme otherwise it will not load.
Posted on May 12, 2008
SOURCE: digital photo album with keychain
Mine I bough from wallgreens and it has a technical support website (www.mscustomercare.com) you can download the program there.
Its really cool.
Roberta
Posted on Aug 24, 2008
  • 5 Answers
SOURCE: not able to format my pendrive
Make sure you are attaching your pen drive into an USB 2.0 port (also called "high speed USB port"). It must be formatted to FAT32, if it still fails you might try the HP USB Disk Storage Format Tool. If you are using Windows 98 then you need special driver for your pen drive.
Posted on Dec 22, 2008
Need OptiPix Pro software
A simple google search will help greatly, I searched for you and apparently the official source is not easily found. Here is an alternate source, beware that it may not be valid.
http://optipix-pro.software.informer.com/
Jan 11, 2016 | Photography
RE: omnitech 8.5 digital picture frame. smartparts tells me to connect usb cable but it already is connected. tried reloading software, same problem.I am trying to copy photos to the picture frame.
I had same problem today, my software on the PC was version 3.03, I upgraded to 4.1, it seems to work better now.
These frames are a little flaky, sometimes I have to power it off, and on, for it to be recognized.
software at
http://www.smartpartsproducts.com/content/support/optipix/index.php
Oct 03, 2009 | SmartParts (1DPFSP01) Digital Picture...
Need replacement stand for Digital Optipix Pro Picture Frame
Since the original manufacturers do not seem able to help, you may find one on eBay
Sep 12, 2017 | Smart Parts Digital Picture Frame
I am not able to transfer my pics from my pc to the smatparts internal memory using optipix. I go through all the steps but they dont appear on frame.. any ideas
There are generally the following types of problems, one is that it could be hidden, or in the wrong format, try some kind of a reset. secondly,maybe the card is faulty or some kind of electrical problem has made it incapable of writing( somethinglike low battery maybe) Hope this helps
Jul 24, 2009 | SmartParts INC. digital frame. 7.0 in....
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Can't transfer photos from computer to digital frame
1. Install EasyShare software (free download at www.kodak.com/go/sw)
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
No USB Port on SP70BRS Digital Picture Frame
Put a memory card into a card read/writer and, once you've edited your pictures, place them on the card insert that in the frame and either use them from the card, or transfer them into the onboard memory.
Dec 07, 2008 | SmartParts INC. digital frame. 7.0 in....
SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
Nov 27, 2008 | SmartParts (1DPFSP01) Digital Picture...
Computers & Internet Logo
409 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
