Question about Toto Toilet Onepiece Ultramax MS854114SL.12
The chain keeps getting tangled and the toilet keeps running. The chain is very difficult to untangle
  • 2,237 Answers
There is too much slack in the chain. when the handle is at rest, there should be very little slack in the chain. and when you flush, don't slam the handle. also, if the handle is all the way down when you flush and the flapper is being pulled too high, leave a one link slack. and the hook that holds the chain, clamp it closed to avoid the chain getting rehooked on it.
Posted on Nov 13, 2009
Toilet keeps running
Just go to Lowes and get a replacement KIT. They are not costly and they are easy to install.
Feb 17, 2018 | Home
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 | Home
How do i untangle the cable fro my spare tire on my 2009 Jeep Grand Cherokee?
Yes, the cable is tangled internally. It only rewinds evenly with a load (such as a spare tire) on it! The assembly will have to be removed and disassembled to untangle the cable or replaced.
Feb 08, 2015 | 2009 Jeep Grand Cherokee
Window blinds
I don't know about fixing them after they've become entangled, but I do know a thing or two about preventing them from ever getting tangled in the first place. One idea I've heard is to put the string inside a clear plastic straw, which would then help prevent the adjacent string from get tangled up with it. If you do have a serious tangle issue, sometimes it is easier to just replace it rather than try an untangle it. Or you take the whole unit off the wall and untangle it that way.
Feb 19, 2014 | Select Blinds 2 1/2" Deep Wood Blinds...
Kickstart aint working.... how do i fix this?
sounds like u sheared he role pin on the ger ortiming chain has broke and wrapped around the gears had a 500xr that broke the chain like i said
Dec 16, 2012 | Pit Bike 125cc 4 Stroke Dirt Bike
Newly installed toilet is intermittently running and tank empties if water supply is shut off.
Sound like the flapper is not sealing. Check to make sure taht the chain or whatever controls the flapper movement is not too tight, holding the flapper up and, that it is not so loose that it gets tangled and/or gets caught in between the flapper and sealing surface. You should maybe be able to hear the toilet leaking and if so, push down on flapper and, if the leak stops, you have definately found your culprit. The first thing I would do is check the adjustments and if all else fails, replace the flapper and see what happens. Unless it's leaking on the floor, it's really the only way you would lose the water out of the back tank, unless you could possibly have a cracked or a bad seal on the overflow tube assembly.
Jun 25, 2011 | Kohler K-3654-0 Persuade Two Piece...
Toilet which keeps running, but not every time. I have to jiggle the handle to make it stop
If you take the top off of the tank you will see a lever about 12 inches long that the flush handle moves up and down. To this is attached one end of a small chain. The other end of the chain is attached to the actual flush valve (which might be a flapper or a plastic column. The chain is probably getting a little tangled so that it does not allow the flush valve to return all of the way back down. You can confirm this by waiting until it happens again, then remove the tank top and look before you jiggle the handle. You might be able to remedy this by moving the hook on the end of the chain that is getting tangled. However, I have had better luck by replacing the chain with a flexible, but durable cable. I happened to have some large o-rings, which I cut, then put a knot in each end (after installation). Nylon string might work, but be sure to fuse the ends with a match. If you want to try the o-ring idea, go to any automotive service shop and ask them for a large o-ring, about the size that are used on disc brake pistons. Good luck.
Apr 26, 2010 | Kohler Home
My champion 4 two piece comfort height elon toilet keeps running. I have to turn the shut off valve off to stop it. Help! John
take off the tank cover and you'll see "the flapper" not sealed against the hole where the water goes to the bowl, the chain that holds the flapper might be tangled or flapper is real bad,.....you'll see what the problem is,..
Jan 19, 2010 | American Standard 2002.014 - Champion4...
The toilet refill seems to keep running, but there's no flooding just refilling.
Open the back tank cover and check the "flapper" it is the black thing that the chain pulls up on to let the water out of the tank. If it does not go all the way down tight then the water will just keep running through the toilet and out the drain.
Sometimes it will crack and then not seal, someimes it gets brittle and the edges roll up so it isn't flat and the water runs through.
The chain can also catch or tangle and bcome too short holding the flapper up.
If all else fails there should be a valve on the bottom left side at the fill ppe. Turn that off till you can get it repaired.
I hope this helps youout to get your problem solved.
Thanks for using Fixya!!
Heatman101
Nov 23, 2009 | Washing Machines
Toto Toilet  Onepiece  Ultramax  MS854114SL.12 Logo
2,171 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
