Question about Brother MFC 420CN All-In-One InkJet Printer
I can not get my printer to print at all. it says
I can not get my printer to print at all. it says unable to initiate. i have unplugged the printer checked all the ink, uninstalled and reinstalled the port. any other idea's
    Sniper:
  • 60 Answers
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Posted on Feb 03, 2010
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
My printer is connected to computer, however the on button is not on, screen shows initiating then small block goes on , but it does not engage to print.
Hi there, my name is Lisa and I'd be happy to help. I understand you are unable to print. Let's start with a hard reset. To do so, leave the printer on and unplug the power cable for 1 minute. While it is unplugged, hold down the power button on the printer for 10-15 seconds to release any built up power, then after the minute has passed, plug the printer back in.
If the issue persists, I'd recommend you download and run the HP print and Scan Doctor. The HP Print and Scan Doctor is a free utility (tool) that helps to quickly resolve common printing, scanning and connectivity issues: www.hp.com/go/tools.
If you require further assistance please comment on my response and I will gladly do all I can to help. Thanks.
I work on behalf of HP.
Jun 29, 2015 | HP 7210 OfficeJet All-In-One Printer
Unable to initialize out of the box?
Lots of printers come with paper or cardboard parts keeping the internal moving parts stabilized during shipment. You have to open the printer up and pull that stuff out. Maybe that's your issue.
Apr 03, 2015 | Brother International Brother MFC-J4510DW
Unable to open printer(read error) this is the error message I have received. I have turned off the printer and the computer but the message is the same. I also deleted the printing job, turned everything...
try to remove printer from add printer wizard, unplug cable and insert, found new hardware must be appear, from that locate driver manually to initialize. restart pc and run test print wizard.
Mar 25, 2010 | Canon I960 InkJet Photo Printer
Printer Problem
The computer and the printer are not talking properly.
Most likely the printer is unable to come online and thus cannot be initialized.
Michael
Jan 21, 2009 | Lexmark X85 All-In-One InkJet Printer
Error 30
I have the MFC 465CN - I was receiving two error codes:
Unable To Clean - Error 30
To fix, I first cleared the memory by unplugging the printer, then holding down the red stop/exit button, keep it held, power up the printer, and dont let up the button until it finishes the start up.
I then pressed the "ink" button and performed a cleaning, alignment, and quality check. After this, everything worked fine.
DO NOT try to print anything from your computer or have any pending print jobs while doing this - it appears that pending print jobs, or anything in the printers memory was interferring with the initilization and cleaning cycle it performs.
Hope this helps...
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
HP Laser Jet 3200se fax machine
Hi..
The service error refers to an hardware issue with the printer.. U can try the following step,if this didnt resolve the issue only option is servicing.
1. Unplug printer.
2. Press and hold SYMBOLS & ENTER/MENU.
3. Continue to hold down the buttons while you plug back in the printer, through the entire
power-on sequence.
4. When display reads PERMANENT STORAGE INITIALIZE or HP LASERJET 3200
release the buttons.
Jan 09, 2009 | HP LaserJet 3200se Printer
Initialize Error
1. reset absorbers counter
2. if #1 does'nt work, see for mechanical problems...
If you're never disassembly your printer - call service...
Nov 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to clean ... Brother MFC 3240C
Machine Error 46, Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An initial purge, for example, advances the purge counter by 187 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unusable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again before continuing to the steps below.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the up arrow key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
May 27, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
79 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
