Question about E-Machines eMachines Desktop PC
Just got new power cord...machine shutsdown, power meter registers it has power supply
  • 11,896 Answers
Power supply itself is likely faulty.
Posted on Nov 11, 2009
Empty machine not running
any display , led blanking , etc if not check fuse, power cord , or connectivity of power cord through multi meter if no connectivity found , issue will be with main supply, fuse or power cable
Dec 31, 2014 | Washing Machines
I have the RJTECH 4200 Karaoke Machine. Worked fine for over a year and recentlt loaded a CD and the power shut off. Tried everything, can't get it to turn on. Need help on getting repaired. p.
A repair if total dead is possible. Follow the money or the voltage in this case from cord to switch and from there to power supply--should be AC or wall voltage up to the power supply and then get rectified (changed) from AC to DC.
If no AC voltage past the switch--test it with a ohm meter--off no reading, on a reading etc.
May 27, 2012 | RJ Tech RJ-4200
Need a power supply cord for a JVC XL-SV22 kareoke machine
There's nothing special about the original power cord, so I'd go to Radio Shack and get it for $8
http://www.radioshack.com/product/index.jsp?productId=3875429
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-XL-SV22BK-CD-Players-manual/id/313ag925/t/2/
Mar 15, 2011 | JVC XL-SV22 CD Player
I have a 13 month old LG fridge model LFC 20745st that just died, no lights nothing. Any ideas? There is power to the outlet.
Recheck your supply outlet carefully. Plug in a high draw load with something like a hair dryer to make sure there is adequate power.
Inspect the power cord of the machine carefully.
Was the machine just moved or did someone roll the refrigerator over the cord ?
Check the condition of the cord carefully. Remove the back cover and follow it up to where it enters the junction box area.
Some household critters love chewing on cords.
The cord itself may be bad. You are not in serious trouble, but need the use of a VOM meter to trace the power.
Calling a service tech who knows LG machines should find the problem with little trouble, and the cost would be minimal.
Nov 03, 2009 | LG Refrigerators
No power, no lights on laptop
I think you should check the real power supply ... 120 V in and what comes out ... volts (ac - dc) and amps or what fraction of an amp.
Please compare the old with the new power supply. The new power supply should be the same volts - same kind (AC or DC) and at least the same amp rating. You can use higher amp rating but not lower - lower will burn up - literally)
Volt meter ... always set it above the suspected voltage. Batteries are always DC. Houses, buildings, etc always AC. Power supplies - could be mixed - ac in and dc out.
So if you were measuring in your home, you set the meter to 130 or higher on the AC scale. If you were doing your auto, 24 volts DC (or so).
House current, probe color doesnt make any difference. Should read about 120 Volts between the narrower (or right side/ground down orientation) or the two slots and the wider of the two shots (wide should be the neutral side - ground on the bottom). You can prove the hot side by measuring to the ground. White wire to ground = no reading. Black wire to ground = 120 volts. (The black and white are INSIDE the electric outlet. You can use either probe to do the measurement.
I hope this helps you.
If you have more question, please let me know.
Thanks for using fixya.com
a
Oct 23, 2009 | E-Machines M5309 Notebook
Machine shutsdown hard shortly after boot
OK, i experience this before, i think your situation is mostly like mine, and this problem may cause by the your laptop power adapter, please replace a new adapter and see how is the result. Hope this help.
YBC (/\)
Oct 07, 2009 | E-Machines 6809 Notebook
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
Can't get laptop to boot - power supply issue?
even AT 20% it should turn on Doubt it has anything to do with the power cord. Check that the battery is correctly seated in the housing and there is no corrosion evident.
Aug 12, 2009 | Computers & Internet
Mx35 no power
Hi, can you use a multimeter? If so then check on the power suply what the voltage output should be for that unit. Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have. If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit. Regards mistyman
Sep 01, 2007 | Toshiba PA2502U - Libretto 100, 110,...
E-Machines eMachines Desktop PC Logo
18 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
