Question about Panasonic Lumix DMC-LS75 Digital Camera
Nice picture but no sound with video - Panasonic Lumix DMC-LS75 Digital Camera
    Problem Solver:
  • 9 Answers
Make sure the volume on the camera is turned up.
Posted on Nov 11, 2009
No Sound on LG Super Blu-Ray Disc & HD DVD
Its something wrong in the cables connection try to reconnect them! And make sure that the connection is perfect according to manual then try it. It should work nicely. Moreove HDMI has great sound + picture effect.
Dec 13, 2007 | Televison & Video
I cannot see anything on the LCD screen or in the viewfinder. It doesnt record video but it recoreds audio
It sounds like the CCD or its circuitry has gone down. (CCD is the cell that receives the light through the lens and turns it into a picture). Only solution is a repair or buy a new camera. If it is still under warranty or very near it, take it back to the dealer, promise him you didn't drop it, and ask nicely for it to be repaired under warranty. If you are in UK, argue your consumer rights if the warranty has just expired - the consumer may reasonably expect an expensive device like a camcorder to last more than a year.
Aug 28, 2014 | Hitachi DZ-MV750MA DVD Camcorder
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
When powered on with remote,makes usual sound,green light comes on,then goes off,blinks 3 times,goes off and contiuesly blinks until unplugged. Problem is picture suddenly went black with no sound.Could it...
my samsung tv model number is sp50L7hx it's 6 years old, when I turn it on it's a not really nice picture just nice sound, after 2 hours the picture is off just sound .... after I was switch off TV and switch on again ... the picture is very bad and just for a ten-twenty minutes ... what's is the problem? I'm never change the lump ... or is it a some problem with T-Con decoders board or is it a lump?
Jun 19, 2011 | Televison & Video
My ECS A530 laptop displays only green vertical lines. can someone please help?
Sounds like you have a bad LCD screen, hook up a computer monitor on the video output located on the back of your Laptop, if the monitor produces a nice clean picture, suspect the LCD screen on your Laptop.
Dec 18, 2010 | EliteGroup A530 Notebook
No picture or sound
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later, it fixed the intermediate problem of no video, when turning on the power.
Here is a picture of what they look like:
Thank you for using FixYa. Have a nice day and please remember to rate this solution as fbe0a70.png if it helps you.
If you have anymore problems please ask me!
Thanks
Dustin Ellse (BearWeb)
Jul 03, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Sound pops and cracks on coax only.
While there are other possibilities, this is a problem which is commonly caused by bad solder connections that form in the tuner. When you're using the video sources the tuner is out of the picture (sorry, I couldn't resist a pun) so you don't see any problem. It's relatively easy to fix, but it means removing the tuner from the board inside, opening the tuner and resoldering the bad connections. This is a nice TV, so it would be worth getting an estimate for the repair. Because of the time involved, many technicians would rather simply pull the tuner and put in a replacement. See if you can find one who will repair the tuner instead. I always did when I was on the road, and it didn't really take that long. It saves the cost of an expensive part.
Apr 22, 2008 | Sony KV-36FS17 36" TV
No picture but sound on the tv
In regards to the Sony KV32XBR450 without picture but sound, mine just had this problem occur yesterday. After doing a quick troubleshooting check, I have found that the problem is most likely a bad tuner, as when I directly connected a video source to the RF (Cable Coax) connector, I wasn't able to get a picture, etc.
I was able to "by-pass" this issue for now, while I wait for the replacement part (special order via Sony Authorized Repair Service Ctr), by using the S-video output from my Dish Network and plugging that into the S-Vedio input on the back of the TV, (you might also have S-video output on your local cable box too). Now I've got a really nice picture, but without sound, so all you need to do is utilize either your Audio outputs from your Satelite Box or Cable Box and connect them to your Audio inputs under the S-Video cable and you'll have picture and sound. If you have a DVD/VCR, etc. with audio feed-thru connections, you can also accomplish this with your standard hook-ups to that device, just select it for the sound while you use video 3 (or 4) where you connected the S-Video cable.
This will let you contact your local repair/service center and see if they can get the parts needed to make the repair. I figure that the parts will run between $40-$120, plus a $50 diagnostic fee (usually applied towards your repair bill), plus the labor charge. If I was having the repair done by the shop, I'd expect to pay around $200-$250 +/-. Not bad for a HD Flat panel TV when you consider that a new Flat panel with 1/2 the resolution (720p) will cost you $450 +/-
and a 1080i is more than double that. Remember that the Sony KV32XBR450 is HD 1080i and 720p in one unit. Hope this helps.
Jan 05, 2008 | Emerson EWF2004 20" TV
Panasonic Lumix DMC-LS75 Digital Camera Logo
133 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
