Question about Sony DHC-MDCCC Shelf System
Wont turn on but a red ligth flashes when off
  • 458 Answers
Power output ic short
Posted on Nov 12, 2009
I was watching TV Sony KDL40s2000 and sudenly the TV shuts down and a red ligth (standby) keep flashing!! I cant do anything! It wont turn on or off!! I need help
It is giving you a diagnostic result by the # of flashes. count the number of flashes before it pauses and repeats. It could be the lamp as well, however, this unit has some common board failures. post a comment with your results and I can help you further diagnose the problem. If you are "handy" the parts can be found inexpensively online. and it's generally a plug n play swapout. Hope this is a good start...
Jun 02, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My car has a small red ligth in side panel by the estering well that is flashing and make a sownd like a emergenci ligths on
probably part of a antitheft system,talk to previous owner or disable it.
TIM...................
Oct 21, 2010 | 1993 Dodge Intrepid
I have camera samsung L83T it wont charge what happens is when i plug in socket green light comes on on charger then red ligth flashes a couple of timers then goes off any answers thanks
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . Just replace it and problem will be solved .
good luck .
please rate !
Apr 02, 2010 | Samsung L83T Digital Camera
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
Flashing ligth
Usually means the battery is not seated correctly or is not charging.
Jan 18, 2009 | Dell Inspiron 5100 Laptop
4 red ligths on my xbox 360.
The AV cable cannot be detected
THINGS TO TRY
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
Jan 18, 2009 | Microsoft Xbox 360 Console
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
KDF-60WF655
5 red flashes on your Sony indicates the power supply for lamp is not working .Or 5 pin harness to it is not seated properly.Possibly needs replacement..
Aug 01, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony DHC-MDCCC Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
