Question about Magellan Crossover GPS
Unit will no longer turn on
After reaching a destination, I turned the unit off, and not cannot get it to turn back on. Ihave tried charging it overnight ans still have no luck
    Top Expert:
  • Magellan Master
  • 78,919 Answers
MOST LKELY THE BATTERY HAS FAILED, THEY LAST ON AVERAGE 2 YEARS
Posted on Nov 11, 2009
How can I start using my new Nuvi 2569 sat nav?
Step Description Step 1:
Warm Up If possible, let the GPS warm up for a few minutes once turned on. This allows the GPS to acquire its current position via satellite. Step 2:
Determine Preferences Choose day or night colors to display a suitable screen for the time of day. Step 3:
Adjust Volume Adjust the volume so the device can be heard over traffic noise. Step 4:
Enter Address Through the onscreen navigation option, enter the street address for the destination. Step 5:
Verify Route Check the listed route for accuracy, adjusting as needed. Step 6:
Follow Directions Follow the directions given by the GPS device to reach your destination. Some models, especially in-vehicle navigation, offer voice directions. Step 7:
Turn Off Once you've reached your destination, turn off the GPS device to save its battery charge. Step 8:
Store Device Store the GPS device out of sight if possible, or take it with you to prevent theft.
Mar 27, 2016 | GPS
I have a 1992 Saturn sl2. I recently had to replace the battery and the starter. The car has been fine but one day it took a few turns of the key to start. When I reached my destination I turned off my...
possible alternator failure take battery out get it charged up then go to auto zone, o'riely and or advance auto and have them check the alternator normally they don't charge for this
Aug 16, 2010 | 1992 Saturn SL2
My aircon unit turns on runs for a minute then indoor and outdoor unit switch off
If this is a LG Airconditioning unit.
It has reached the set parmeter of the safety switch point.
1 The unit could be running on too low refrigerant charge and cuts out on low temperature on the indoor unit coil (-5°C longer that 30sec switch off)
2 The unit might be drawing to much current, to much refrigerant, cutting out on high pressure.
Check the refrigerant charge and check the indoor pipe temperature thermister (calibrated at 5kΩ @ 25°C)
Mar 18, 2010 | LG Heating & Cooling
Tomtom1 keeps restarting itself
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Aug 20, 2009 | Tomtom One XL GPS Receiver
My GPS won't turn on or won't charge
Have you tried replacing the battery.
Wont charge? Sometimes if the battery is totally depleted even the charge light will not go on until the battery reaches a certain level of fill. Are you sure it isnt charging? A new battery will confirm its viability to be able to deliver service in future.
Jul 31, 2009 | Sony NV-U44 GPS Receiver
Zen won't turn on
use a paperclip to push the small reset button on the bottom
Feb 02, 2009 | Creative Labs Zen Digital Media Player
New Nuvi 200 will turn on briefly then turn off.
You need to charge your gps from any external charger and check whether screen is working properly .
Also do firmware update for your gps .
By updating firmware your problem can be fixed .
Jan 22, 2009 | Garmin nuvi 200W GPS Receiver
On a trip ,reached destination turned off gps will not come on. plug it in light comes on but screen is dark held on switch for one min will not respond tryed for last 3hrs no response
Take out the memory card and then reset the tom tom (with a pencil or something sharp), and then put the memory card back in and push the on button. let it charge up for as long as you can.
good luck
chris
Dec 14, 2008 | Tomtom Go Plus GPS Receiver
Memory full is being displayed when i try to go to a new destination and when i try to delete a favourite the unit turns off.
Garmin nuvi 610 T
memory full was being displayed on screen whilst on destination ,sometimes followed by route waypoint memory full .
I found by turning unit off , then holding finger on top left of screen ,and at the same time turning back on again the unit would go into maintenance mode.
Follow prompts on screen to reset waypoint memory.
Mine works as good as gold now,hope this helps!
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Kenwood KNA DV3200
IF there is no route guidance it is because the unit is not receiving VSS information from the vehicle.  Confirm that you are getting the VSS info from the correct source and or use Rostra Precision Control's cruise control guide to confirm your VSS wire.
Oct 12, 2007 | GPS
Magellan Crossover GPS Logo
108 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
