My audix ph150 speaker has very little sound coming out of the none power side. the speaker cable checks good and the power side is loud and clear
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: no sound from built in speakers ive checked
Feed it with an MP3 player, it it still does not work then more likely the power amps inside may have gone out, it will not be worth spending money on getting it repair becuase you will be better off spending the money on a good set of powered speakers that put out 100 time better sound quality tahn the monitor powered speakers.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Jan 07, 2011
  • 5479 Answers
SOURCE: I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and cl
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Posted on Mar 12, 2012
Testimonial: "Thanks very much Cindy. This answers my problem completely. Regards JB3610"
Iphone 4 speaker not loud.
Ifthe volume level is normal using headphones, so clean the speaker side gently with a toothbrush. At times some dust could clog the little holes.
Apr 01, 2014 | Cell Phones
I have a Bose lifestyle 38 and whenever I watch a show with a lot of background sound - ie music in a movie or crowds cheering for sports, it overwhelms the voices of the actors or the sports casters. How...
What makes background sound comes out from Bose lifestyle 38 system is because there is jack cable or a cable that has a jack mouth that brings out a mono sound is being inserted..
Mono cables, when inserted inside a wrong input,it's makes the sound comes out with a background noise just like the one you can hear from it now..it seems as if you are not using the right cable for connection..
To resolve these issue, you will need to use the right cable for connection, by doing these,you will get a clearer sound from you Bose lifestyle 38..
Also it can be from the settings inside the Bose lifestyle 38...So you will need to check both sides to resolve this issue..
You will need to use the manual to know the right cable and the right setting for clear volume..
You can download the user's guide from the below link..
http://www.retrevo.com/support/Bose-Lifestyle-38-Series-III-Home-Theater-Systems-manual/id/524dj979/t/2/
Hope it helped.
Thanks for using fixya..
Aug 15, 2011 | Bose Audio Players & Recorders
Hi, I have an Audix D6 that stopped working (after producing nasty popping sounds when connected), I believe because of a bad combination of unnecessary phantom power and a malfunctioning cable. My...
Take it easy, there is no way to damage a dynamic microphone using a phantom power (assuming that the phantom power is correct). In other words try using another cable at another input to check the mic. In the extremely rare case that the mic has a problem there is nothing you can do, just take care and check the phantom power cause I think that the problem is at this stage.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 21, 2011 | Audix D6 Professional Microphone
One of the speakers when turned on loud, there is humming sound. sound hear like a helicopter engine
we need to do a little bit of fault finding here to narrow down where it's coming from or what is at fault.
First try physically swopping the speakers over and reconnecting (do not just switch the cables at the back of the amp). Is the sound still coming from the same side or has it swopped over? If it's swopped over, it's a speaker issue and needs replacing.
Ok, if the strange sound is still happening from the same side, have a look along the speakers cable path. Is the cable running along side any power cables or extension leads or is it near any wall warts or mains transformers (the type you get with mobile phones, keyboards, answer machines,etc). If so, move the speaker cable a considerable distance away from these. Now, has it stopped or the noise reduced?
If we are still not getting anywhere, see if you can try your speakers on a friend's system and/or try someone else's speakers you know to work on yours.
If his/her speakers are noisy on yours, firstly you have to consider that most sytems at very high volume will produce some noise, but if it's actually quite a loud audible noise that's relatively new to the system, you need to get the amplifer serviced.
Hope this helps
Good luck
Jan 07, 2011 | Audio Players & Recorders
Stopped working
Speakers wire conductors should not touch anything but the points on the amp and one speaker terminal each. Look again.
May 20, 2010 | Pioneer VSX-918V Receiver
Quiet Amp
sounds like you need a preamp. i would need more info to be sure. good luck
Feb 11, 2010 | QSC CX302 2-Channel Amplifier
Little sound coming out driver side speakers on my 04 dodge ram
check the clip on the speaker for corrsion. if it after market check clip thee two wires from the clip to the speaker. drivers side window when fully in the down position grazes the clip. see if that helps.
Nov 21, 2009 | Car Audio & Video
Crest Audio CPX-900 Amp
check the input signal.switch the cables and see if that changes anything.also check the back of the amp for filters.make sure that they are set the same way.check cables on source coming in to amp.ie-quarters to rca's or rca's to xlr's.make sure amp is not set to parallel inputs or bridged mono.
Jun 25, 2008 | Crest Audio CPX-900 Amplifier
Sound and speakers
Check the speakers connections. The speaker cables may be shorted. Turn the unit off, check and correct the connections and turn the unit on. good luck :-)
Jan 11, 2006 | Panasonic SC-AK66 CD Shelf System
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
