Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I drained the air out of my craftsman 26 gallon compressor. Now the screw lets air back through and will not stop even if it is screwed all the way in or not.
  • 986 Answers
Your petcock sounds like you have a blockage or a worn/damaged seat. Go and get a replacement petcock and change it out.
Posted on Nov 11, 2009
It shut off at 50 PSI
Did you try draining the excess water from the tank? Mine does this if there's water in the tank. You'll find a 'petcock' valve at the bottom of the tank. With partial pressure in tank, on screw the vavle slowly until it starts to drain. Let it drain all the water out then reclose the valve and try again.
Jun 18, 2014 | Husky Electric Portable Air Compressor:...
Why won't it pump up past 40#?
If you don't have any air leaks, the cylinder head gasket is probably bad on the pump. Easy fix for less than $10. you can get the parts you need here:
http://www.mastertoolrepair.com/sears-craftsman-919195411-p-48270.html or ebay.com. For around $50 you can get the whole rebuild kit.
May 09, 2014 | Craftsman 20 Gallon Portable Horizontal...
Drain at the bottom screw is up in it but air still coming out it
Did you try to turn the valve the oter way? If that doesnt work you need to replace it.
Oct 01, 2013 | Craftsman 33 Gallon Vertical Portable Air...
Motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Aug 31, 2012 | Husky Air Tools & Compressors
26 gallon model 919.167700 160 psi 1.6 hp Bottom of the compressor has a threaded air relief valve that cannot stop the compressed air from escaping. The compressor is new?! I tried using teflon tape...
if it's leaking from the center ,try loosening it let air blow out & tigthen .--- if it's leaking from the theads try tigthening it some more without breakage //////// this valve is the same as a metal radiator petcock with pipe threads that are tappered // return the compressor if still under warranty or try pipe dope -- check for crossed threads--buy new petcock from auto parts store .....a street elbow & 4'' of pipe & quarter turn vavle from the home depot ( or similer supply store ) works nicley as a replacement / this way you can reach the valve to drain the water with out laying on the ground.--------------1/4 pipe thread i think .
May 31, 2011 | Craftsman Air Tools & Compressors
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Drain valve in Porter Cable air compressor
this valve works backwards, you screw it out to stop airflow. If that doesn't work, replace the valve.
David
May 23, 2009 | Porter Cable 4 5 Gallons 150PSI Job Boss...
I have a 33g craftsmans air compressor oilless
have a 26 gallon air compressor , changed regulator switch but it still wont shut off
Feb 22, 2009 | Craftsman Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
109 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
