Question about Kitchen Ranges
Does not work on "BAKE". I can set the temp but the oven does not reach the required temp. It works fine on Convection and Broil
  • peca01 Nov 12, 2009
    I checked and found a hole in the bottom element. I will replace it.
    Thanks for your help.
  • Kitchen Ranges Master
  • 2,605 Answers
Hi, **Always unplug the unit or shut off the breaker before attempting any repairs on your own** First thing I'd suggest is you review your owners manual and rule out the possibility the timer hasn't been acidentally set for "auto-bake" or some function cancelling out the bake element. If that is ruled out, lets go forward. Is this a unit where the bake element is visible or hidden ? If you can see it, check for any burnt holes. If you can't, you'll need an ohm meter. It is likely a burnt out/open element. Based soley on the info you provided it doesn't sound too serious, i.e. a electronic clock or control. If you can provide a model number I would be better equipped to assist you. Hope that helps move you forward, let me know. Good luck. macmarkus
Posted on Nov 12, 2009
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
Jan 29, 2010 | Maytag Appliances 27" Electric Double Wall...
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Won't bake, but all else works
Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
Dec 22, 2008 | Kitchen Ranges
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Kitchen Ranges Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
