Question about Ovens
Water works but icemaker does not. the freezer barely cools
Water works but icemaker does not. the freezer part bearly gets cold enough, ice forms on the rear wall of the compartment.
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Nov 11, 2009
Ice cube dispenser not working
Hi there, did you find the answer to this problem? We have exactly the same issue. We noticed a burnt smell in the freezer, mainly transferring to our hands when we touched packaging. The ice dispenser was working fine but the ice started to taste funny (a bit like burnt plastic) and had black bits in it. We took it out to clean the tray and since putting it back in, it just won't work. We don't know if we have put it back in wrong or if something has blown. We can still hear the motor when we try to press for ice, but nothing comes out. No water is making its way into the ice cube tray to form the ice, but we still have cold running water. I would be so grateful for any help. Thanks
Mar 16, 2014 | Ovens
Whirlpool 2000 generation plus
Check the power cord if the refrigerator does not operate. Plug it in if it was accidentally unplugged, or try another outlet if that appears to be the problem. Double-check the circuit breaker in your home to make sure it is powered on.
Inspect the refrigerator door if it doesn't completely close, or if it doesn't open easily. It could be that the bins or shelves are out of place, or certain food packages may keep the door open. Also, the gaskets of the door can get dirty over time, so clean them with soap and warm water.
Examine the temperature of the refrigerator. If it's too warm, then reset the temperature controls. Check the air vents inside the refrigerator to make sure they're not blocked. Readjust the temperature if items in some of the compartments are freezing.
Watch for trouble with the icemaker if your model has one. It may take at least one day for the refrigerator to produce ice, especially if you've just installed it. Connect the refrigerator to the household water supply and turn on the supply shutoff valve to get ice. If the ice is gray or has an unusual taste, install a water filter to flush out any minerals.
Fix the water dispenser if you can't pour a full glass of water. The refrigerator's water shutoff valve may be off or incorrectly installed. Wait 24 hours for the water to cool if you've just installed the refrigerator. The water temperature should be no more than 50 degrees F.
Mustang Parts.
May 28, 2012 | Ovens
I have water pooling in the bottom of my fridge, what would it be
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 27, 2012 | Ovens
Ref/freezer not cold , even at coldest setting. Seems bottom oo fridge/frrezer colder than the top.
I have had a similar experience. Ice may accumulate inside the cabinet, adjacent to the thermostat, even on "frost-free" models. This can be especially troublesome if your home or climate isespecially humid. The ice tricks the thermostat into thinking everythingis cold enough, so the cooling unit simply does not turn on, and when it does come on it only refreshes the ice. Your first thought may be to defrost the fridge. You will have to empty the fridge, then leave it unplugged for a day or two. Be prepared for the melt water, it may run out of the cabinet and flow onto your floor. If this does not help, you will probably want to call a service tech, as fridges do wear out. But do your homework, new refridgerators have come way down in price, and there are incentives in many jurisdictions to encourage you to replace older units with newer, more efficient units. You may find it is a better idea to purchase a new one. I hope that this is helpful, Rob.
Jan 01, 2011 | Ovens
Ice continually forming on bottom of upright freezer
you nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Nov 18, 2009 | Ovens
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
Maytag Model MTB2154ARW-water is appearing inside on the bottom of the refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 17, 2009 | Maytag CWE5800A Electric Double Oven
Ovens Logo
122 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
