Question about Electrolux 30" Self-Cleaning Freestanding Double Oven Electric Convection Range - White
Electrolux range won't work. "Cooktop lock"
I used the self clean funtion on my free standing wave touch electric range, and now the entire unit won't work. Error code is "cooktop lock"
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
IFIXALL
  • 868 Answers
SOURCE: Replacing Glass Cooktop on GE JPB82
1st....You have to pull out the cook top first.2nd...remove the 1/4 inch screws that hold the top down(they are mounted on the side os cook top ) ,you dont remove the lowest ones.remove the burners from the top and your there :) Please Rate This !
Posted on Jun 07, 2008
SOURCE: Electrolux Induction Cooktop: My husband
Power down, then back up. You will be lucky if that fixes it though. I had the same problem here. It is in-warranty so I called Electrolux. Parts came in only after requesting them multiple times. Repairman put them in and they were bad. After a month it is still broken. I was promised a new unit, but little real action. Electrolux is a horror. No way to DIY this thing, too complicated. Cut your losses and buy another brand.
Posted on Aug 11, 2008
SOURCE: How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Posted on Jan 23, 2009
SOURCE: Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
Posted on Sep 10, 2009
What does code d-o mean
Good Afternoon friend, that's a great question!
From my understanding your Electrolux range is displaying a code of "d-o". The code could stand for open door, could be missing a sequence, or a miscommunication within the control panel. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. Hope this information is helpful. -Matt
Mar 09, 2015 | Electrolux Wave-Touch EW30GS65GS 30"...
My Electrolux wave touch range won't turn on after self clean.
Hello friend, thanks for your inquiry!
I understand that you have performed a self-clean on your Electrolux range and now your display is not showing. From the information you have provided it sounds like the control panel may have shorted out or a wire to your panel may have shorted out. I recommend reaching out to a technician for further assistance with properly diagnosing your range. Hope this helps to some degree. -Matt
Sep 30, 2014 | Electrolux Kitchen Ranges
Hello CRemo, thanks for your inquiry!
We have an Electrolux Wave Touch a Dual Fuel Range and cannot use self clean upper often feature due to flashing "remove racks" message . Have removed all racks, and ensured rear vertical metal bar is
Hello friend, thank you for your post!
I would perform a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. Upon restart I would operate self-clean to see if it will allow you to do so. If your appliance will not start self-clean you could be seeing a problem with the UIB (user interface board) or EOC (electronic oven control) and I would suggest having a professional come out to properly diagnose your appliance. Hopefully this is helpful. -Matt
Sep 04, 2014 | Electrolux Kitchen Ranges
When in self clean mode latch will not lock latch has been replaced what do you think is causing this
If you replaced the entire lock assembly and it still does not work, the control board was originally at fault.
I assume there is no latching action when you call for self clean?
Double check you installation before you go buy a new control board.
Also check wire harness connection from new latch assembly to oven control board.
Oct 23, 2013 | Electrolux 30" Self-Cleaning Slide-In...
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
Wave touch panel comes out of sleep mode by itself
Your range should have a two year part and labor warranty so contact Electrolux to schedule service. They will preorder and ship you the parts prior to a servicer arriving.
Mar 21, 2009 | Electrolux EW30ES65GS 30" Slide-in...
Electrolux 30" Self-Cleaning Freestanding Double Oven Electric Convection Range - White Logo
221 people viewed this question
Top Electrolux Kitchen Ranges Experts
Mike Henne
Level 1 Expert
Dominic
Dominic
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
