Question about Kitchen Ranges
Replaced selinoid. When i connect battery the selinoid turns over
  • 89 Answers
Have you checked the starter switch sounds like that is hanging up
Posted on Nov 11, 2009
When I try to connect my battery wire to the Terminal, and what do you mean I have no ignition motor trying to crank?
Your wire to the starter selinoid has some how bypassed the key switch or the selinoid is bypassed or mechanically stuck closed. The selinoid is a magnetic switch that closes the curcuit for the larger starter wire You must to make sure you are connecting the wires to the correct spots.
source:obd2 tools car diagnostic tool
Nov 08, 2013 | Cars & Trucks
My eclips dont start or wen o put the key it dont klic
bypass starter selinoid by connecting 2 big posts with screwdriver if it turns over it is a bad starter selinoid if there is no sparking and knothing else happens you have a bad battery or battery connection
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Does not fill with water
selinoid just above connection of water inlet hose may have burned out. Get a replacement fro your local appliance parts store and with the water -under the sink- turned off, replace the old with the new. Of course, you should have checked to ensure that the two wires connected to the selinoid are properly connected!
Jan 05, 2012 | LG Dishwashers
Selinoid buzzing
You have bad connection. Check all cables from battery on. If you ohm meter, they cheap,go from battery to solenoid.(12v) From solenoid to starter, may haveto turn the key. Check all wires good connections, You change a lot parts, back track your find the problem. GOOD LUCK
Nov 30, 2011 | Husqvarna Garden
1997 t-bird clicks when trying to start replaced
The starter selinoid is on top of the starter. This engages the starter when you turn the car over. Did the starter you bought have a selinoid on it?
Jun 19, 2010 | 1997 Ford Thunderbird LX
1990 nissan pu sev6 new starter good battery , wont turn over sounds like the selinoid clicks once when the key is turned
sounds like a poor battery connection or corroded wires where they join to the connectors. clean and/or replace.
May 27, 2010 | 1991 Nissan Pickup
Can not get motor to turn over put new starter on and new selinoid but do not know if i have selinoid wired right
check and see if the red wire goes to starter and the other to the battery and the litte one to the s on the selinoid
Jan 23, 2010 | 1984 Ford F 150
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
