Question about 3M MP 8625 Multimedia Projector
NOT WORKING IT TURNS OFF THE IMAGE, AND THE "ON" AND "TEMP" LIGHT TURNS ON, WHAT IS WRONG WITH IT? HOW CAN I FIX IT?
  • 2,237 Answers
It may need a good cleaning. blow the dust out of it with canned air. dust keeps in the heat that the projector is trying to expel. also make sure the fans all work, and replace as necessary.
Posted on Jan 27, 2010
Why does the bubbles come on when I turn on the heat
Wrong site, But here you go. I worked on these. Two things that possibly could be wrong. The temp sensor. Or the PC/logic board. Most times it was the board. It's been ten years since I did one. But putting a electronic board, unprotected around water, isn't a good idea. The last one I couldn't fix cost $400.
Aug 31, 2014 | Cars & Trucks
Viewsonic pjd5111 projector has temp and lamp light on. not turning on
Hello
Check whether its cooling fan works or not. If there is any fault to the cooling fan, these symptoms you describes here can occur.
Feb 07, 2012 | ViewSonic PJD5111 Projector
I have a Panasonic Model PT-50LC13 flat TV. Was working when got it brought it home, it is used and now when I go to turn it on --- we get a green light then a flash of 5 yellows blinks then no light for...
This tv has 3 indicator lights on front, Power, Lamp and Temp
I assume Temp light is blinking 5 times after every 5 seconds, if that is correct then it is problem of clogged air filter located in light engine that need to be cleaned.
Below is an image of light engine and air filters locations are marked with red circle, it is job of professional to fix this issue because complete light engine need to be take out from tv cabinet.
Hope these info will help you, let me know if you have additional question or need service manual copy if you want to repair tv by yourself.
Thanks.
Nov 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Instrument panel guages don't read accuratly
I have a chevy cav 03 and my problem is just in the gas guage and temp guage now i cant seem to figure out how to fix it but for a quick fix i have jut been pulling out the instrument panel fuse and putting it back in it seems to fix t
Feb 26, 2009 | 2000 Chevrolet Cavalier
Blinking red and green lights no image. I've replaced the lamp
you might have the lamp in wrong, it should have a metal clip on both sides, one of them is probably bent. If you bend it back it should start right up
Jan 10, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Flashing Blue power light
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 25, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Princeton Monitor VL1917 - No Power
This is the way how to examine what's wrong with your LCD monitors. After you turned your pc on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 23, 2008 | Princeton Digital VL1918 Monitor
Power light flashes yellow then green
I used to repair LCD monitor from Dell. It works. Most of LCD monitor brand have the save main components such as CCFL lamps, inverter board, power board. You might be using these following steps to examine what wrong with your monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 18, 2008 | Balance CM2015 15" LCD Monitor
My sony FLASHES 4 times
STBY LED flashes
2 times pcb X SUS TEMP (DD CON
3 times pcb Y SUS TEMP (I/O Block)
4 times Center TEMP
5 times Digital 5 volts
6 times PANEL FAIL (PDP)
try unplugging it for a while, from other forums looks like they sent them back to sony for repair
Dec 10, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Problem with monitor going black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU1.gif and monitor. After it goes black, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Oct 30, 2007 | Relisys RLT1720 17" LCD Monitor
3M MP 8625 Multimedia Projector Logo
59 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
